Distributor for LSVT with LS wiring harness ?
Old Aug 5, 2002 | 11:48 AM
X2BOARD's Avatar
Default Distributor for LSVT with LS wiring harness ?
1997 LS wiring harness...
I am running an LSVT setup: B16a head with B18a block. I am having distributor problems, but the question I have is this.... When I needed a destributor, the LS one did not fit the B16 head, and the B16's distributor's harness plug does not fit the LS's wiring harness for the distributor. I simply swapped the LS internals into the B16 housing and this worked fine, but I had a jumpy tach on occasion.
Is the LS distributor internals the SAME as that of a GSR or SI distributor's internals ? They all bolt up like budda... but are the same things, or are my LS internals being stressed.... or even losing Hp ?
X2
Old Aug 5, 2002 | 06:53 PM
str8loco's Avatar
Default Re: Distributor for LSVT with LS wiring harness ? (X2BOARD)
i have the same setup as you do all i did was swap the distributor connectors
Old Aug 6, 2002 | 04:17 AM
Jeff C's Avatar
the ls dist will fit the b16 head, you just need to cut off the leg closest to the vtec solenoid. i have one on b16 head right now and 91civicsi has one on his gsr.
not sure about the internal question though...sorry.
Old Aug 6, 2002 | 06:48 AM
X2BOARD's Avatar
Default Re: Distributor for LSVT with LS wiring harness ? (Jeff C)
I fixed my little distributor problem yesterday and got my car started... during my little adventure, I tested my ICM and determined it to be at fault, so I swapped it for an older B16 distributor's ICM, which had a different model number on it.
I guess we can now make the assumption that the LS ICM is different from the B16 ICM... although they look almost identical... the B16's, however, is a hair thicker than the LS's, but doesn't cause any fitment issues.
X2
jdmdohcek98
Oct 13, 2008 09:56 AM
DasaEJ1
Nov 5, 2005 06:38 PM
jccrxtuner916
Oct 16, 2005 12:23 AM
TRE_
May 4, 2004 08:18 AM
juggernaut
Feb 14, 2004 06:10 PM
