Rear Top Hats
Old Jan 4, 2009 | 04:23 PM
raffaelli's Avatar
Default Rear Top Hats
Any idea where I can source some press in studs on the rear top hats or any idea what size they are?
Old Jan 4, 2009 | 04:52 PM
xci_ed6's Avatar
Default Re: Rear Top Hats
take them to a fastener specialty store (ie: Fastenal) or order the new top hat from Honda, it's only $24.
Old Jan 4, 2009 | 06:41 PM
raffaelli's Avatar
There is a fastener shop nearby. I will try them, thanks. I have not pressed the old one out yet. Any idea what size it is?
Old Jan 4, 2009 | 07:36 PM
acmoc's Avatar
14 mm I think.
Old Jan 10, 2009 | 06:26 PM
raffaelli's Avatar
They are actually 10mm.
I stuck out at the local fastener place. Autozone and Advance said goto the dealer. THe dealer diagrams I saw online to not list a part number for the stud alone, just the entire hat. I'd hate to have to spend that money on an entire hat when I only need the stud.
Thought about using a bolt and grind the head down. Not sure how strong that would be.
Any thoughts?
Old Jan 10, 2009 | 06:40 PM
crx2nr822's Avatar
Im sure you could go to a junk yard and find another top hat for super cheap
Old Jan 10, 2009 | 07:03 PM
raffaelli's Avatar
No crx's in the area. You know of a chassis that uses the same hat?
Old Jan 11, 2009 | 05:39 AM
fireant's Avatar
I think all the civics/crx/del-sol from 88-2000 use the same ones in the rear.... pretty sure if it looks right it is. If I'm wrong, it will still have the stud you need.
Old Jan 11, 2009 | 07:01 AM
raffaelli's Avatar
thanks.
f22b-dohc
Honda S2000
Jan 30, 2008 06:46 PM
crxss outhe eyes
Dec 8, 2005 08:54 PM
Racermech
Dec 20, 2004 04:34 PM
the-one1
Jul 19, 2003 02:50 PM
metal-x
May 11, 2002 12:49 AM
