Can`t Figure Out Blower motor Problem
Old Jan 4, 2009 | 01:23 PM
EH3forlife's Avatar
Default Can`t Figure Out Blower motor Problem
Ever since I bought my 98 coupe I have been having issues with the blower no matter what the combination is (heat, A/C, recirc, outside whatever) when I turn the fan on to 1, 2, or 3 it dosent blow but when I turn it to 4 it blows at full blast. So far i have replaced the blower speed switch ( where you choose from 1, 2, 3, 4) and the blower motor. What else is there to replace? Has anyone had this problem before?
Old Jan 4, 2009 | 01:27 PM
2000siturboR's Avatar
Default Re: Can`t Figure Out Blower motor Problem
my cousin had the same problem with his 91 teg. we tried everything thing to fix it could never figure it out. did everything you did still nothing ever fixed it.
Old Jan 4, 2009 | 01:30 PM
snowball's Avatar
There probably is a resistor in the circuit, probably mounted on the side of the blower casing.
Old Jan 4, 2009 | 01:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
there is a blower control resistor. it is not uncommon.
usually when it craps the bed, you loose the 1-2-3 and only works full bore.
hth.
Old Jan 4, 2009 | 01:34 PM
EH3forlife's Avatar
Where exactly is this located?
Old Jan 4, 2009 | 01:38 PM
snowball's Avatar
The resistor is $20.71 + shipping/handling at majestic honda. The handling is usually $5 and shipping $15 so you're better off ordering more stuff at once or getting the resistor off a junk.
Old Jan 4, 2009 | 01:40 PM
snowball's Avatar
Go to majestic's site, or another honda dealer that has exploded diagrams. It will show you where the part is.
Old Jan 4, 2009 | 01:43 PM
snowball's Avatar
Also, you can check page 21-10 in the helms manual, has trouble shooting and a picture.
Old Jan 4, 2009 | 01:46 PM
tech7427's Avatar
all you need to do is set your test light lead on power, backprobe the ground wire on the blower motor and see if the resistance changes when you mess with the blower speed ****. obviously the light will dim and get brighter or nothing, then you know the resistor is bad.
Old Jan 5, 2009 | 02:51 PM
CountDracura's Avatar
Yeah, it is a simple fix. The blower motor resistor pack is partially blown. The pack itself is rather unexpensive and is easily replaced. Look behind the glove box and it's basically plug and play. This is a very common problem.
Old Jan 5, 2009 | 02:58 PM
98civdx's Avatar
Master Detailer
heres a diy fix for you with pics.
https://honda-tech.com/forums/tech-misc-15/blower-motors-works-speeds-3-4-but-not-1-2-fix-how-2082345/
[S]niper[W]olf
May 19, 2015 06:06 AM
jdmhondamotive
Honda Insight & CR-Z Hybrid
Sep 26, 2012 05:36 PM
D_koschak
Jul 13, 2009 02:15 AM
em1blk2000
Jan 9, 2009 08:08 AM
dc4drewH
Mar 25, 2005 02:36 PM
