strength of the b20b block?
Old Jan 4, 2009 | 10:35 AM
katurbobeast's Avatar
Default strength of the b20b block?
i was evaluating an eg honda civic with a b16a/b20b frank yesterday with some friends who have been building honda race cars & engines for some 18 years now. they claim that the stock b20b block sleeves are weak and are a breaking point once u cross 7500rpm and that im looking for more headache out of the buy than anything unless it was rebuilt with aftermarket sleeves, pistons, rods & bearings,etc.
anyone have experiences with this?
Old Jan 4, 2009 | 03:19 PM
mouab18c1's Avatar
Default Re: strength of the b20b block?
it should be fine. Know your limits..but yes the frankenstein motor is a headache unless built properly
Old Jan 4, 2009 | 04:33 PM
blackGSRcoupe94's Avatar
yeah word, they are fun while they last, just be easy on her. lol good luck.
Old Jan 4, 2009 | 05:05 PM
jdm602's Avatar
not so much the sleeves with the rev limit. although the sleeves are quite thin, they wont hold much boost when turbo'd or high compression all motor even. a lot of people resleeve em' although that goes for just about any motor. ha.
Old Jan 5, 2009 | 08:53 AM
CerealKiller's Avatar
what all three have said.
Old Jan 5, 2009 | 01:34 PM
its funny though, i had a B20B i purchased from a buddy, just to see how much it could really take, borrowed my buddies chipped LS ecu, (to eliminate rev limiter) and slammed it with a 75 shot on it and ran the **** out of it, took it to the track for S&G. ran 13-0 consistent all night about 10 passes. left that night went out to beat on all the ricers that hang out on our local "strip" played around with this STI for about 5 mins lost to him light to light about 3 times, so i pulled over changed the jets with out knowing the shot size(come to find out later it was about a 175 shot) went back out to hunt his *** down, pounded the $hi+ out him hard, the car redlined the car at about 9k OOOOPS. but it took all that and still sort of ran, well on 2 cylinders while i started my hike home to rip it out. just a story i thought i would share about my old B20B.
Old Jan 5, 2009 | 02:59 PM
Golden Eagle's Avatar
b20 stock sleeves are 100% a weak point they are the weakest sleeves out of all Honda b sires blocks
Old Jan 5, 2009 | 03:42 PM
xander1100's Avatar
i think it all depends on your tune. my old engine was a b20 before i had to change it for CA emissions laws. LOOONG story but when i was driving it across country i was pushing 10 LBS of boost (it had a fully built up bottom end) and on this one area in texas i was at 8k RPMs in 5th gear for about 40 miles while running from a tornado. broke apart the engine when i got to cali (was about 2.6k miles across country) and my engine was just fine. was running 10:1 compression. no clue how fast i was going, my speedometer got messed up before that and showed me going 30 MPH faster than i really was so needless to say it was showing above 140.
Old Jan 5, 2009 | 03:51 PM
no its the way there made it is a well known fact that there the weakest sleeves. some get lucky but most don't we get more b20 stock sleeved blocks with cracked sleeves then any other Honda block
Old Jan 5, 2009 | 03:57 PM
hmmmm how much would it cost to rebuild and re-sleeve this block with aftermarket sleeves, pistons, rods, bearings + bolts?
i am thinking about buying the car and pulling the block to rebuild it. the only thing thats stopping me from buying the car is the fact that it got a little hit on the front right side corner and the straightener didnt do much of a good job bringing it back 100% straight.
i think im gonna take some pics of it all and post it up so yall can take a lok and criticise, would that be cool?
cause i do like the idea of the b16a/b20 frank instead of a more expensive K swap, ive been told by the same ppl it makes mad power. but i want it reliable for everyday driving, cause i do not want to have to granny shift at 7000rpm if the engine can make power up to 9000rpm, or b racing someone and ooopse there goes my block, thats just gay !!! i love my high reving motors !!
and is it possible to attain the 10:1CR with this frank on stock b20 pistons?
i wouldnt cross 10:1cr cause of the gas we get here which is 95octane max.
Old Jan 6, 2009 | 03:03 AM
xander1100's Avatar
if u do the work yourself not too bad price wise. all new parts:
pistons about 500ish
rods 300ish
sleeves about 600
ARP bolts about 300
so about 1700 or so before labor etc
Old Jan 6, 2009 | 11:42 AM
pm sent
Old Jan 6, 2009 | 11:46 AM
rods 300ish
sleeves about 600
ARP bolts about 300
dont know who told you $600.00 for sleeving but they were wrong most shops will not even sleeve a b20 or if they do they say no warranty. we do sleeve then and also give them same warranty as all our sleeves but its more around $1010.00 for sleeving a b20
Old Jan 6, 2009 | 11:55 AM
jdm602's Avatar
im guessing hes saying the sleeves cost about that much. well, it sounds about right.
i know benson does sleeving for 900.
Old Jan 6, 2009 | 11:56 AM
but from what i know bensons no longer sleeves b20s like i said most dont i could be wrong about bensons but thats what i have herd
Old Jan 6, 2009 | 12:02 PM
jdm602's Avatar
oh im not sure if they still do b20's or not. i was just saying thats what i member the price being for their sleeves.
Old Jan 6, 2009 | 01:53 PM
xander1100's Avatar
was giving the price for the actual sleeves, forget teh brand, not the labor/machining/etc
Old Aug 5, 2009 | 09:12 PM
tomkng42's Avatar
New User
all i can say is should be fine with stock sleaves b20 are thicker than b18 b18 is like 56 57 mm and a b20 is 77mm thick ??
Old Aug 6, 2009 | 07:57 AM
Originally Posted by tomkng42
all i can say is should be fine with stock sleeves b20 are thicker than b18 b18 is like 56 57 mm and a b20 is 77mm thick ??
wow back from the dead not sure why your posting on a 7 month old post but as we said above it is a known fact that the b20 sleeves are week a lot weaker then a b18 and that has nothing to do with the thickness of the sleeve it has to do with the way they are made
Old May 16, 2010 | 01:11 PM
EG6-SMASHING's Avatar
i have a b20b non vtec in my da9 183whp stock bottom end head work only ported and polished new valves springs retainers ect. running with toda vtec killer cam shafts and toda cam gears havent had problems with it yet i redline 8k
Old May 16, 2010 | 08:18 PM
seanbev24's Avatar
Hahahahaha. FAIL.
Old May 18, 2010 | 07:41 AM
fasthatch95's Avatar
The b20 sleeves r weak cause they ride off the walls together for as the others have there own sleeve and cast. Look at them side fom side you will see a major difference in the decks.
Old May 18, 2010 | 03:10 PM
xzodiackillerx's Avatar
B20b or B20z sleeves are one piece all four cyl. and have a bigger bore than the other B series.
tempsohc
11
Aug 18, 2010 10:43 PM
drunknbass
Jul 5, 2003 07:13 PM
torr
Mar 6, 2003 08:00 AM
teg92
Nov 4, 2002 08:42 PM
2 litre EG
Jan 30, 2002 10:29 AM
