Heater Core Removal time
I don't have any heat, maybe just something plugged in the heater core or maybe its dead. Anyways, about how long does it take to do the job, i just want to know so i don't get started and i have to end up pulling an all nighter, thanks.
I've done two of these now. Its alot of work because the dash has to be pulled to do this. i don't know the whole story behind your car, but just make sure your not low on coolant, there is not air in the coolant system, etc. I have never had to replace a heater core in a Honda because it was bad. That dosn't mean anything I know, just trying to save you alot of work if not needed. My 2cents
Well, it had been sitting outside for a year with burnt coolant in it, so its probably just plugged. I flushed the coolant and i didn't bleed the system per FSM, just how i usually do, so i guess i'll try and bleed the coolant again, and see if i get any changes, thanks.
would love to see any updates with pictures. i started on mine but cant figure out how to get my dash out so im kinda stuck (cars put up for the winter anyhow with other projects) but id love to see how you get this dash out without pulling your windsheild out. im stumped on my 00si
my girls car needs her heater core replaced too....shyt leaks coolant...only throws heat when the car is like on the highway.. making real heat....I was thinking of doing it...but car is up for sale instead.....let the nextt owner worry bout it.......f*ck it
