sluggish when the car is warmed up.
Old Jan 4, 2009 | 01:31 AM
Tizzakowack's Avatar
Default sluggish when the car is warmed up.
well i need some suggestions. i have a 92 h22a swapped lude.
when i start it up and drive it around its drives perfect until the car is at proper operating temperature then it boggs down and just doesn't want to go at all in all gears and rpms.
it will eventually get up to speed but it just runs overall like crap. what could this be?
Old Jan 4, 2009 | 06:01 AM
mattsnooz's Avatar
Default Re: sluggish when the car is warmed up.
I would say check ignition timing. Any cels?
Old Jan 4, 2009 | 11:12 AM
no cels and the ignition timing is perfect.
Old Jan 4, 2009 | 01:03 PM
drove it again today. it does it right when the temp hits half way on the gauge.
plugs, and wires are brand new. new fuel filter.
could it be a 02 sensor? coolant temp sensor? knock sensor? Distributor?
Old Jan 4, 2009 | 01:33 PM
royalfelix's Avatar
does ur car smoke excessively by anychance? the 02 sensor starts reading after the car is warmed up could be.. but it would throw a cel. check to see ur cel anyways maybe the light on the check engine light went out?
Old Jan 4, 2009 | 01:52 PM
i know the light works. cuz before i wired v tec like a few months ago it was on so i know it works. the car doesn't smoke too much there is a lot of thick white smoke but that might also be cuz its 10 degrees outside.
accordlx5speed
Sep 10, 2014 05:27 PM
preludedriva
Oct 21, 2006 03:47 PM
mooseknuckle
Jul 9, 2003 10:03 PM
fe519
Dec 29, 2002 06:56 PM
