d15z7
Old Jan 3, 2009 | 09:35 PM
jdmjonny21's Avatar
Default d15z7
has anybody heard of this engine?? ive seen one on my homies car but he wont tell me how he got a hold of it!! that thing is hella fast stock 3 stage v-tec any body have any info bout this engine??
Old Jan 4, 2009 | 12:10 AM
93formula's Avatar
Default Re: d15z7
http://forums.trinituner.com/forums/...5z7-114061.htm
[edit] D15Z7
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Compression : 9.6:1
Power : 128 hp (130 ps) @ 7000 rpm & 102 lb·ft (14.2kg/m) @ 5300 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-2 MPFI
Old Jan 25, 2009 | 08:19 AM
Jimster480's Avatar
Default Re: d15z7
ya its pretty sick.
Old May 21, 2009 | 10:02 PM
Big[V]'s Avatar
Default Re: d15z7
D15Z7 130ps max output. over 550km per tank of fuel (using stock manual S40 or CVT M4Va)
Most importantly shares the same feature as K20A-R i.e. rod/stroke ratio of 1.62
It also means if done correctly will see power pushing to 8000rpms.
Old May 21, 2009 | 10:10 PM
mitsubishiv5's Avatar
Default Re: d15z7
so its got features of a k series yet its a d series?
Old May 22, 2009 | 02:34 AM
Big[V]'s Avatar
Default Re: d15z7
something like that. But it does not mean it has the same specific output. Both motors are for completely difference reasons.
If the Z7 can be prepped for performance I don't see why it can't reach K20A specific output.
Old May 22, 2009 | 06:58 AM
Jimster480's Avatar
Default Re: d15z7
its 3 stage vtec is the best thing about it. Think turbo car with 40-45 MPG city tuned?
Old May 28, 2009 | 07:02 PM
Big[V]'s Avatar
Default Re: d15z7
There's Japanese guy who slapped a low pressure turbo kit on bone stock motor. No effect on econo driving unless WOT all the time. Plus he also commented he is using CVT and surprisingly the gearbox is holding up to the power. He's probably pushing close to 200ps with his setup.
Old May 28, 2009 | 08:32 PM
Jimster480's Avatar
Default Re: d15z7
heh, thats not bad.
Old May 28, 2009 | 11:07 PM
Big[V]'s Avatar
Default Re: d15z7
Originally Posted by Jimster480
heh, thats not bad.
Here ya go! btw The car is a Vi-RS.
http://www.youtube.com/watch?v=ce3KR3dBVo0
http://www.youtube.com/watch?v=yVQtpe3M_Lo
Old Jun 27, 2012 | 05:38 AM
Nitrous1024's Avatar
Default Re: d15z7
That does not sound plausible.
Old Jun 27, 2012 | 08:00 AM
Red-Rocket's Avatar
Default Re: d15z7
http://www.hmotorsonline.com/shop/sc...age&item=30021
here's where your buddy got his motor more than likely, very reliable dealer
Old Jun 27, 2012 | 08:39 AM
Default Re: d15z7
Silly question, how do I build a D-series engine for 150-180HP at the crank without boosting it? I don't have much space in my seventh generation civic for a turbo kit, and a K20 swap is too expensive for my daily driver (which I'm converting from a auto to manual gearbox).
Old Jun 27, 2012 | 06:19 PM
CRXcaliber's Avatar
Default Re: d15z7
1. Take off air intake tube and expose the throttle body butterfly.
2. Have someone get in car and rev motor to 6000 RPM.
3. Hold $1500 to $2000 cash in mouth of throttle body and let go.
Not gonna happen w/o boost or a hell of ALOT of cash...if you are lucky. Sorry. Not saying it can't be done, but you are waaaaay better off spending your cash on a B series swap if you don't wanna boost it. If you wanna add a little boost, get a D16z6. You can reliably get 200 to 250 HP and still have decent MPG with some bottom end work to handle the boost. That's what I'm planning myself. Just my two cents worth.
Old Jun 28, 2012 | 02:30 PM
LSx Envy's Avatar
Default Re: d15z7
It is possible.. Get on D-series.org.. There's guys over there with that kind of power and netting 50mpg..
You've gotta spend a good amount of duckies to swap a Bseries correctly.. If you want something with more power its easier to start with a better base IMO. But don't let anyone tell you it can't be done. There is one guy that used mostly all OEM parts and rebuilt an engine that gets 150whp..
And back to topic, the D15z7 is BALLER.. I drive hondas for what they are.. Fun ECO-Boxes.. 130bhp and the possibility of 50mpg?? Thats a wining recipe to me. Won't win any races but should be more than enough for some spirited driving...
recklessgoon16
Oct 17, 2012 01:29 AM
KRZRICAN
May 20, 2009 03:52 PM
LSXFEIND
Feb 26, 2009 08:36 AM
efjones9
Dec 5, 2008 08:19 AM
i_am_a_black_man
53
Jan 2, 2008 03:04 PM
