Lug Nuts
Old Aug 5, 2002 | 10:08 AM
greensleeper's Avatar
Default Lug Nuts
I got these damn lug nuts that require a little adapter for a normal lug wrench. And I can't seem to get them to stay tight. The wheels are hubcentric if that means anything.
Also when I get them all tightened down it seems like some of the lugs will screw farther in than the others. This only on the front driver side. The rest are fine.
Suggestions? Where did I screw up? Is it possible to overtighten these type of lug nuts? I don't think I could of since I only used to stock lug wrench.
[Modified by greensleeper, 2:08 PM 8/5/2002]
Old Aug 5, 2002 | 10:24 AM
smokin rubber's Avatar
Default Re: Lug Nuts (greensleeper)
Yes you can definatly overtighten the wheel lugs with the stock wrench.
Old Aug 5, 2002 | 09:21 PM
91cordpos's Avatar
Default Re: Lug Nuts (smokin rubber)
Have you driven it yet? Is the wheel wobbly?
Old Aug 6, 2002 | 09:49 AM
Default Re: Lug Nuts (91cordpos)
no it doesn't wobble.
I took a closer look and two of the lugs (opposite of each other) appear to be at the correct depth (when compaired to the other three wheels). one of the lugs won't go in far enough. and the last lug is in too far.
If I fucked up my new wheels I'm gonna be pissed. But I took my car in today to get my brake upgrade done. and asked the dude to take a look at it. We'll see what he has to say.
Old Aug 6, 2002 | 09:51 AM
Brandon's Avatar
Life is Suffering
Put some washers under the lugs.
Old Aug 6, 2002 | 10:00 AM
Default Re: Lug Nuts (F22turbo)
you go first - let me know how it goes.
Old Aug 6, 2002 | 10:01 AM
Brandon's Avatar
Life is Suffering
It is the best way to avoid damaging the rim. I have already done it.
Old Aug 6, 2002 | 10:22 AM
ohh you're not kidding - that doesn't seem very safe. the lugs I got seem to look like they are supposed to fit down into the lug hole (they have a little lip)
triumph_013
Feb 5, 2013 11:25 AM
BLK2DOOR
Apr 13, 2010 09:36 PM
Knestis
28
Jun 29, 2005 10:24 PM
Confuc1ous
Jan 17, 2004 04:24 AM
KF_S2000
Feb 2, 2002 02:51 PM
