O2 sensor help!!!!!
Hi, im David im new here on h-t i recently got a 1991 honda civic hatchback with a ls swap from a 90 integra. My problem is that the O2 sensor in screwed into the header but i have no idea where the wire goes to? If it helps i believe it is the car's stock wiring harness. Can someone tell me where to plug the O2 sensor, it is a 1 wire type and the car is OBD0 with a pr4. So please tell me where the o2 sensor wire goes to. Pics would be great if possible and yes i have tried to search threads for hours. Thanks
Thanks everyone that helped but if i cant find the plug can i just go directly to the ecu plug find the pin for o2 sensor and then splice a new wire and run it to the o2 sensor?
its a round one wire plug kind of a greenish colored plug larger than average
Addon: The wire is white and just incase for some reason it is gone its pin c16
i couldnt find it because it was not connected in the first place and then i couldnt find any plug that wasnt used so i guess ill have to just run it from the pin c16. Thanks
1992cxcivicEG
Dec 18, 2009 07:42 AM
tomek5x
Jan 21, 2008 09:56 AM
redhatchb18
Oct 23, 2003 09:27 AM
