wanted to share my 10 second build
https://honda-tech.com/forums/showth...4#post36890314
would the mods please move this to this forum from the delsol/civic one thanx
If you want a build thread add some useful info. Right now all I see is pictures. This will be locked if it continues to be a picture thread. Please read the ruels
its a gsr bored to 84.5mm has a turbonetic t6 tomzilla, tial 40mm waste gate, full race manifold, individual coil packs ran by a msd digi 4, aem 30-1040 computer, stage 3 dss axles, car is tuned @10lbs for the moment and did 350whp due to stock crx fuel lines, and not getting alot of fuel from the tank to the 100cc injectors. I have it in kansas city ks right now getting a full eromotive fuel system dropped in it so we can get some real hp out of her.
also twin disk clutch/lsd tranny
I have not done any passes on the track as of yet so I am waiting for our season in March to start in KC.
ILL NEED A ON/OFF KILL SWITCH IN THE BACK SINCE MY BATTERY IS LOCATED THERE. I also need to get the cage done as well.
stock valves/hypertech springs/stock head/gsr cams/eagle gasket/stock gsr crank/manley rods/cp pistons/morroso deep sump pan/toda timing belt
I am getting ready to ditch the msd digi, and go M&W Pro10.
My original build was a stroker, but the rod end caps around the crank stripped the bolt completely put of the rod, and ripped the water jacket out of the block also
I have been told that drums are fine for the 1/4, and there is really no need to upgrade to disk at this time. I am going to slowly transform this into strictly a strip car eventually.
how well the crx its being modeled off of does 10.2 in the 1/4@30lbs, and in the area of 690whp.
the pro-am civic with the same build ran 9.8 in the 1/4.
so your correct its not 10 second crx as of yet thats why its still a build, and in March it will be on the track.
build meaning still in the process of being completed.
this crx ran 12.3 on an all motor ls/vetec that layed down 227whp.
Where you the driver?
