Low frequency to High frequency VSS help
Basic problem, i have a countershaft speed sensor style trans (05-08 rsx-s) with 02-04 harness with newer k-pro....(k-pro has the fix)
Car is 2000SI
i've seen alot of posts on other web sites about using a box to slow the speed of the counter....not into that.
I have the countershaft pig tail and its wired up as if it were a 05+ rsx to the ecu.
In the k-pro i can go to Misc and switch it to 05+ rsx countershaft...done that and its not working.....
Anybody else know what im doing wrong or has done this? Not switching cases or wiring in a box, nor buying another trans.
thanks...
Car is 2000SI
thanks...
Is the k-pro seeing vehicle speed while you drive? Is it just the car's speedometer that isnt working?
Even better, have your tuner fix it when you pay him to tune the car.
10psiLsEf2
Dec 12, 2011 07:02 PM
Mr.Burner
Jan 5, 2009 11:18 AM
