Gearbox linkages
Old Jan 3, 2009 | 03:58 PM
hayzer's Avatar
New User
Default Gearbox linkages
Woundering if anyone can help?
Doing a build on a ef9 civic and the Both gearbox linkages are broke and bent?
Do integra type r ones fit or can you suggest any
thanks
Old Jan 3, 2009 | 04:11 PM
www.megameet.org's Avatar
Default Re: Gearbox linkages
What trans are you using?
Old Jan 3, 2009 | 04:47 PM
zCivic's Avatar
Your gonna have to go with an aftermarket one for any b-series swap. Hasport, Avid, unless your can find an OEM one from an 88-91 SI-R
Old Jan 4, 2009 | 06:09 AM
hayzer's Avatar
New User
im using a cable y1gearbox?
Old Jan 4, 2009 | 06:30 AM
Just use any linkage from a single cam civic.
Old Jan 4, 2009 | 06:34 AM
hayzer's Avatar
New User
are you a 100percet theyll fit man?
will the teg r ones not fit?
Old Jan 4, 2009 | 01:12 PM
zCivic's Avatar
No
that wont work a Y1 is a B-Series transmission. The D series use totally different end on the stabilizer bar to the transmission. B series slide on to the transmission with a bushing and D-Series go into a bracket. Will not work unless going to cut and weld using 2 different linkages.
Will need an aftermarket one, an OEM 88-91 SI-R, unless you want to cut and make one using a 90-93 integra shift linkage.
efhatch1991
Jun 29, 2013 10:34 AM
streetsold6teeny8
18
Jun 29, 2009 10:18 PM
E_F_9
10
Apr 12, 2007 02:46 AM
JDMHatch101
Mar 23, 2004 11:18 AM
MrHunter602
Mar 8, 2004 09:32 AM
