jacked up ignition switch
Old Jan 3, 2009 | 02:14 PM
boost fed ls's Avatar
Default jacked up ignition switch
Here is my problem, i have been working on my 94 civic over at my buddies house. He decided to move it one day. Instead of getting the key that i left in the ash tray he busted my ignition. I can not seem to put it back together and get it to work right. My question is is it easier to get another ignition switch or just put a push button start on it?
Old Jan 3, 2009 | 03:27 PM
tech7427's Avatar
Default Re: jacked up ignition switch
just get another ignition cylinder. dont try to fix it or rekey it. its not that hard.
Old Jan 3, 2009 | 05:34 PM
i am going to assume you mean from a junk yard? now on the cylinder, do you have to dremel what looks like rivits?
Old Jan 4, 2009 | 07:18 AM
fcm's Avatar
fcm
Old Fart
Start by giving your friend a swift kick in the ***.
If damage is limited to the key cylinder itself all you need to do is replace the cylinder, not the whole ign. switch/cylinder housing.
If the housing was also damaged then yes, you will need to dremel/drill out the sheer bolts, [rivets].
Hint, if you go to a bone yard for a new ign. switch housing assembly, [with key] don't forget to get the door key cylinders also, [so you need only carry one key].
Feel free to PM me if you have questions. 94
Old Jan 4, 2009 | 09:43 AM
tech7427's Avatar
you can usually get away with a chisel and hammer and chisel a slit in the sheer bolt and turn it while hitting the chisel with a hammer
fazalabbas
Jan 5, 2019 10:36 PM
chillerice
15
Jan 27, 2013 12:47 PM
Bishop1976
Oct 3, 2012 08:31 AM
GoldCoin
Oct 24, 2007 12:09 AM
