obd0 obd1
well i know i have a 89 civic ef came with the jdm dohc zc swap and was going for a gsr swap with is obd1 and most efs have obd0 but noticed my ecu says on it saying 93 integra aint that obd1 whats some tips i could use to tell on other parts let me know peeps thanks
ecu codes:
https://honda-tech.com/forums/showth...ecu+92+integra
read the link, read your ecu and viola what you read is what you have.
All EF and DA ECUs that I've seen have the date of manufacture stamped in black ink on them.
Still, that's not as accurate as going by the part number since it is possible that the car may have had a new ECU installed at some point in its service history.
Always verify the part number from the ID sticker on the side of the ECU case.
Well the ECU code is kind of iffy. There was an OBD1 and an OBD0 PR4, seen many of them. Check the ECU plugs where the ECU plugs into the harness. If there all grey its OBD1 if theres 2 black ones and a green (on ECU side) that plug will be white on harness. Also can check under your hood at the distributor (unless the plugs have been changed which I've only had luck with the 9pin round connector) If there white and round its OBD0 and if square and Grey OBD1 you can't use an OBD0 with OBD1 ECU and vice versa
The last section of the part number can make a difference even if the middle section is the same. For example, a PM6-A09 ECU from a '90-91 Si has updated maps and is much more desireable than a PM6-A08 ECU from an '89 Si for ST-class autocrossing due to the 300 RPM higher rev limiter.
909ej
Dec 31, 2010 09:11 PM
