Just had clutch installed and now wierd noise
Old Jan 3, 2009 | 05:15 AM
Redprelude98's Avatar
Default Just had clutch installed and now wierd noise
right after i had my clutch installed and flywheel resurfaced there is noise that i keep hearing and it will continue until i press on the clutch pedal a little bit, could this be my throw out bearing and if so do i just need to change it or is it ok to let it make that funky noise, or what would you do?
Old Jan 3, 2009 | 05:58 AM
96teggynonVtec's Avatar
Default Re: Just had clutch installed and now wierd noise
Lots of cluthes make noises when they are being broken in... Not sure if thats the noise you are speaking of though.
Old Jan 3, 2009 | 07:03 AM
RomPirate's Avatar
So i'm assuming the throw out bearing WASNT replaced?
Its likely its the throw out bearing... New pressure plate = stronger spring = more force on old TOB.
Old Jan 3, 2009 | 09:39 AM
teefunk01's Avatar
definitely throw out bearing
Old Jan 4, 2009 | 10:04 AM
is that a real expensive fix, like does anyone know a price range because my mechanic isnt really open right now and i am trying to figure out a price and plus i just got a speeding ticket for 25 over and now low on money but just trying to figure out?
Old Jan 4, 2009 | 10:22 AM
iwanttokillgod's Avatar
input shaft bearing not throw out bearing
Old Jan 4, 2009 | 12:31 PM
RomPirate's Avatar
The part itself isnt expensive, its about $25. Its the labor that kills because its basically a clutch job all over again. You have to drop the transmission to install it. If you can change a clutch, you can replace the TOB.
huh? Its much more likely to be TOB seeing as it wasnt replaced with the new clutch.
93 EG
12
Mar 3, 2007 08:14 AM
00siandrew
Apr 13, 2006 05:09 PM
tegtuner94
May 17, 2005 07:20 PM
sracing
Aug 27, 2003 09:50 AM
