Cold slushbox issues
Old Jan 2, 2009 | 08:43 PM
ChevelleSSLS6's Avatar
Default Cold slushbox issues
Here in the mitten state it's cold... and our subject is my 1990 Civic lx sedan automatic... aka Econobeater II...
Our story begins- In the summer and autumn, when it's warmer, the transmission shifted fine regardless of temps and showed no odd symptoms. Now it's wintertime, and in the cold it seems to not want to shift out of second gear until the engine is warmed. Today I was cruisin along 35mph @ ~4000rpm. I ended up going a bit slower to keep the revs closer to 3500 (figuring that mower engines run 3600rpm and last forever, that wouldn't hurt).
Once the coolant temp gauge stabilizes in the normal area ('water' at the base of the thermometer symbol) it might continue this for a little, but almost immediately shifts normally.
What I did so far...
I checked the transmission fluid with the engine and tranny warm (stop car, hold in all 'gears' for 10 seconds x2 and check fluid in neutral, engine running) and it appears to be ok.
I'm considering draining the tranny fluid and refilling, but I don't have an owners manual for it so I'll search for specs (what grade of trans fluid, capacity for a drain-and-fill) if the general consensus seems to say 'go for it'. I've just heard of a lot of guys messing their autoboxes up with new fluid as it dislodges otherwise harmless gunk that gets stuck in a valve or passage inside the transmission.
Since it operates normally when warmed up, I don't think it's a transmission mount issue as posted on a thread found during a search.
Old Jan 3, 2009 | 09:59 AM
Default Re: Cold slushbox issues
update: there is a leak where the shifter cable goes into the tranny. Am I not checking the fluid right?
alphalanos
Honda S2000
10
Feb 1, 2012 12:28 PM
dannyp2
Acura TL, RL & ZDX
May 4, 2009 05:51 PM
ChevelleSSLS6
Transmission & Drivetrain
Jan 4, 2009 08:38 PM
AnAccordIsForever
Oct 14, 2005 01:28 PM
97AccordLx
May 2, 2002 01:38 PM
