Striped LCA bolt
Old Jan 2, 2009 | 06:54 PM
Jdmglenn's Avatar
Default Striped LCA bolt
I was trying to take off my oem lca's and I rounded off the 14mm bolt.
What can I do???
Thanks in advance
Old Jan 2, 2009 | 08:45 PM
johnls's Avatar
Default Re: Striped LCA bolt
are you going with aftermarket control arms if so just take a angle grinder and cut the bolt on both side of the arm and heat the bolt up on the side thats has the threads one the shock and back it out with vice grips had to do it before
Old Jan 2, 2009 | 08:59 PM
turbo83lude's Avatar
If you were using a 12-point socket, try using a 6-point socket. Apply some heat and penetrating spray.
Old Jan 2, 2009 | 11:03 PM
.Smitty.'s Avatar
That bolt is the biggest PITA evar. I ended up using a grinder to just cut both sides of the shock mount and replaced everything with aftermarket. Make sure you really grease that bolt when you put it back in so it doesn't happen again!
Old Jan 3, 2009 | 12:11 AM
Jdmglenn's Avatar
oh wait the shock bolt comes right out. It's the one that connects the lca to the trailing arm that's being a ****!
I gathered up some air cools and im gonna go at it again in the morning.
Old Jan 3, 2009 | 03:08 AM
nihad's Avatar
Sears/craftsman sell special sockets for rounded heads..
Old Jan 3, 2009 | 04:22 AM
Blackcatn2o's Avatar
I was thinking just about that,
Old Jan 3, 2009 | 06:39 AM
kyden's Avatar
just cut the bushing out. the threaded end should just turn by hand.
Old Jan 3, 2009 | 10:11 PM
Jdmglenn's Avatar
awesome news. I barrowed this Craftsmen stripped head remover set from a friend. Hammered it on and the bolt came right out. Very recommend this set.
Old Jan 4, 2009 | 06:49 PM
nihad's Avatar
You are welcome
Old Jan 4, 2009 | 08:57 PM
cua0's Avatar
well you could find a bigger nut and weld it on the bolt, then heat up the other side a little with a torch and twist it off while the outer metal is warm.
(heat expands metal)
Old Jan 5, 2009 | 05:08 AM
rice4life's Avatar
heat will not work because it will melt the rubber bushing, and then the metal sleeve inside the bushing will just turn the bolt, that's usually the part that seized.
use the special socket for striped heads, with an impact wrench if you can. you might end up breaking the bolt head off. in that case, cut the nut off which is probably welded on, then remove the LCA and use a punch to remove the bolt or drill it out. i have broke several of these bolts off before.
Old Jan 5, 2009 | 10:13 PM
nihad's Avatar
Hey guys he said he has it off...
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
Setsuna F Seiei
May 12, 2006 09:15 PM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
LsNer00
Jun 29, 2004 12:09 PM
CoolKat
42
Jul 17, 2003 08:36 AM
