need help with z6 head
Old Jan 2, 2009 | 12:00 PM
rickscrx's Avatar
Default need help with z6 head
i just bought a 90 crx and it has a d15b2 block but has a z6 vtec head on it. the vtec is not hooked up. the motor seams to run well runs a little rich though. my ? is will running without the vtec hurt the motor or anything. also it has a ecu from a 91 crx si. i am new to hondas so be kind to a new honda guy
Old Jan 2, 2009 | 12:41 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: need help with z6 head
it isn't optimal, but it won't hurt anything.
If you want it to run well, you should get a p28 or equivalent ecu and hook up vtec, the 4wire o2, and get a z6 distributor, and you will notice a big difference..
Old Jan 2, 2009 | 01:35 PM
rickscrx's Avatar
i know it does not have the origianal distributor. i think its a t0-2.
what distributor came on the z6. also will i need an engine harness for the p28 ecu. sorry for the noob ? but like i said i am new to the hondas.
thanks again for the help.
Old Jan 3, 2009 | 03:24 AM
rickscrx's Avatar
anyone else have any suggestions.
Old Jan 3, 2009 | 03:33 AM
crx_si-r's Avatar
the TD-02u distributor is the stock 88-91 si distributor from a D16A6 (1.6L non vtec) motor. yes you will need a jumper harness to plug the P28 ecu in, and for an obd1 D16Z6 head the correct distributor to use will be a TD-42U you will also need to re-pin your current engine harness to plug into the new distributor.
Old Jan 3, 2009 | 05:05 AM
rickscrx's Avatar
thanks alot.
Old Jan 3, 2009 | 10:58 AM
daveb91's Avatar
I didnt think the A6 dist. would fit on the Z6 head right...as in the adjustment is way off and you need to cut one of the mounting "ears"?
Old Jan 3, 2009 | 11:31 AM
90.EF.Si's Avatar
i believe you do cut one
Old Jan 3, 2009 | 11:46 AM
93formula's Avatar
yeah the obdo dist needs to be modded.
just so there is no confusion, you need a obd0-obd1 jumper, a p28 ecu for manual trans prefferably, the z6 dist, 4 wire o2, heres the link for the dist wiring you will have to repin:https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/obd0-obd1-distributor-wiring-1349052/ , and that should be all..
thisxlaosxguy
Apr 23, 2013 05:49 PM
pigvwj
28
Aug 17, 2012 08:51 PM
rpmraper
10
Jun 12, 2011 08:25 AM
EFstyle
15
Apr 19, 2008 05:02 PM
bn2r_dk35
Jul 23, 2007 08:11 AM
