Squeeling sound from belt? Help!
Old Jan 2, 2009 | 10:20 AM
#Leo#'s Avatar
Default Squeeling sound from belt? Help!
I have a problem. Today my friend and me changed belts and belt tensioner and water pump on my 1990 Civic D16. After we started the car there was some squeeling sound coming somewhere from the belts or tensioner, or the cam gear. Could that be 'cause we overtighten the belt or we didn't tighten it enough? Has any of you experienced something like this?
Old Jan 2, 2009 | 12:10 PM
91dxsedan's Avatar
Default Re: Squeeling sound from belt? Help!
is it like a slipping belt sound if so check how tight it is and if its ok then an old trick is to rub a bit of bar soap on it and then run it
Old Jan 2, 2009 | 12:21 PM
Dkahn18's Avatar
WELL , IMHO its either ***** cold out? or its wearing down the letters and writing on the belt. Everytime i change my belts they squeak for 100 miles or so then gtg..
Unless of course its just loose..
Old Jan 2, 2009 | 10:36 PM
jhammond_82's Avatar
Reject Papi
water pump bearings already? idk. i'd say tighten the belt and/ or try some prestone belt dressing.
Old Jan 2, 2009 | 10:45 PM
93formula's Avatar
well is it your timing belt or your alternator belt?? take off your alternator belt first and see if the noise is still there, the tensioner usually does its job, but if its too tight it will be noisy, not squeeling though....
Old Jan 3, 2009 | 03:59 AM
#Leo#'s Avatar
I'm pretty sure that it's not the alternator belt....we will take it apart on Monday, and try to put it on again and see what happens, but few people said to me that it is a usual thing, that noise, when belt is new.
Old Jan 3, 2009 | 09:51 AM
ChevelleSSLS6's Avatar
mine squeals after hitting a puddle... belt slippage.
Old Jan 3, 2009 | 05:11 PM
~sp33~'s Avatar
EFB055
Theres something seriously wrong if your timing belt is squeeling.
Old Jan 20, 2010 | 08:23 AM
4g4dcruisin's Avatar
i have this same problem! sohc zc squeels at idle from time to time, i have to rev at 2000rpm for it to go away...then starts again at idle or downshifting.
Old Jan 20, 2010 | 08:33 AM
spens 91 Ef's Avatar
i had the same problem recently with my alternator belt a autozone 1 brand new and tight as i could get it but still lose and stretchy so i put the old 1 back on and hasnt squeeked since
Old Jan 20, 2010 | 11:45 AM
InTheLBC20's Avatar
thats weird, i just changed my water pump and timing belt the other day, and mine squeals a little also. It only does it between 2000 and 3000 rpms though. I was thinking its my tensioner but i will let it go for a while to see if it stops, as someone said its the letters and numbers wearing off...
rodz
Mar 2, 2016 07:43 PM
phat00civic
Mar 7, 2012 06:30 AM
boostedefhatch
Mar 18, 2009 11:02 AM
VTECth1s
Aug 30, 2006 10:24 PM
dizzogotvtec
May 13, 2006 01:49 PM
