boosting a dohc ZC
i've tryed searching, but this new search feature is whooping my butt.
Im looking at ~220 - 250 whp for my CRX. Its already got a dohc zc swap, and i'm really just looking to boost it and run mid - high 13's.
I've read that the stock block can hold up to 300 as well as stock internals? Is that correct? Would a 14b turbo do the job for my goals? Any help is appreciated.
Really, if your going to turbo your car, unless you're poor or running a really low boost, you should always build the engine to cope with the higher stresses a turbocharger puts on the internals.
Just because you may have heard it held 300hp on stock internals, doesn't mean it held it for more then a few days.
Okay thank you guys.. here is what im thinking.
Compression test
T3 50 trim
wiseco pistons
eagle rods
some kind of front/side mount
act clutch
and TUNE TUNE TUNE!!!
Any ideas or opinions on which is better then which for internals and others
Compression test
T3 50 trim
wiseco pistons
eagle rods
act clutch
Well you don't need that much whp to get mid 13's.
I pushed a small HIH turbo to 6psi on a stock motor and ran 13.504 with turboedit and some 450cc DSM injectors. Estimated running about 170-180hp in a 2000lb CRx.
So, the setup your thinking about should easily get you in the 12's.
SLO B18
22
Dec 3, 2020 01:28 PM
Grandhustleman86
16
Jan 13, 2007 09:12 PM
