Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Can't disengage out of Park
Old Jan 2, 2009 | 06:22 AM
Drokit22's Avatar
Default Can't disengage out of Park
I have a 07 Accord, 2.4L engine. I could not disengage out of park. I pressed and held the brake pedal many times and let the car run for 45 minutes but still could not get out of park. This occurred at 8:00 AM when the temperature was 4 degrees. It was like the car did not sense the brake pedal being pressed down. At 2:00 PM after the sun shined on the car for six hours I was able to disengage out of park. Any ideas on what would cause this problem.
Old Jan 2, 2009 | 06:39 AM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default Re: Can't disengage out of Park
Brake light switch on the brake pedal will cause this. Your brake lights would not have worked either.
Old Jan 2, 2009 | 08:41 AM
HONDAPARTSMANMIKE's Avatar
bring it to your dealer it needs a brk light switch i have replaced a few of these for this problem. when it happens chk to see if you have brk lights...
Old Jan 2, 2009 | 01:30 PM
tortuga89's Avatar
good info u can replaced ur self is really easy
Old Jan 2, 2009 | 05:01 PM
Honda Tool's Avatar
Yes by why spend $30 on the part when car is under warranty.
Old Jan 3, 2009 | 12:16 PM
tortuga89's Avatar
^ yep
Old Jan 3, 2009 | 02:21 PM
^ x2 just bring it to the dealer
Old Jan 3, 2009 | 02:31 PM
Targa250R's Avatar
be professional
I concur on the sticky brake pedal switch diagnosis. We've replaced several of them now. Take it to the dealer if you're still within the warranty mileage.
To drive the car, remove the shift lock cover (the small covered slot located next to the shifter in the center console) and insert the ignition key into the slot. This will release the shift lock mechanism and allow you to shift the transmission to neutral so that you can start the car. Keep an eye on your mirrors while driving as your brake lights may not be working.
ihonda
21
May 31, 2012 09:53 AM
asocallocal
Aug 29, 2010 07:00 PM
EGKevin209
Jun 22, 2010 12:41 PM
PREACHERBREW
May 20, 2008 02:09 PM
Psyco609
Jun 12, 2004 09:30 AM
