Giant part out!!!
Alright guys, here it is. I'm just gonna make a list and if you have a question just ask:
-B16 head, this head is spotless. was sent to engine lab of tampa for cleaning and a 3 angle valve job. has itr springs, retainers, gsr cams, vtec solinoid, golden eagle cam plug, and the 2 coolant sensors. No dizzy. head has already been tapped for ls/vtec, but i have the plug to put back in it in case you're putting this on a vtec block, just let me know. SOLD
-Tial BOV. silver, brand new in the box. all fittings, flanges, and gaskets SOLD
-Tial 35/38mm wastegate. part is used, works fine, was removed to go 44mm. silver also, will include new gasket and dumptube SOLD
-Hasport auto to manuel b series mounts. these mounts allow you to drop in a b series motor w/ manuel trans. into any eg/dc automatic chassis. no cutting or welding required. the timing belt mount and rear mount are used, but the trans mount is brand new $350 OBO
-MSD pro billet distrubutor setup for b-series vtec heads. includes 2 external coils, 1 used, 1 brand new in the box $400 OBO
-Intercooler piping. Piping was coated black, was in an eg coupe, but will fit with minor mods. already flanged for a tial bov. includes couplers and tbolt clamps $200 OBO
-Intercooler. this is a custom intercooler using a griffin core and custom endtanks. it has a few battle scars, but does not leak at all and has been proven to work on a 500+whp car SOLD
-JG edelbrock intake mani setup. for b16/type-r. This includes a brand new iacv and brand new hondata intake gasket, SOLD
-Brand new Tony1 Bosch saturated 1000cc injectors SOLD
-Brand new Skunk2 composite fuel rail. has fittings already installed to run steel braided feed and return lines. will include fittings to run stock lines also. $225 OBO
-UGR cast b series turbo manifold. has a central located 38mm wastegate flange and is brand new in the bag $200 OBO
-b series in eg/dc shift linkage, will include brand new set of energy suspension shifter bushings $100 OBO
I'll post pics and the measurements when i get home. the size is pretty close to a precision 600 i/c. i think mine is actually a little taller, but like i said, i'll get measurements when i get home from work.
Same for the i/c piping. i'll measure it later and post it up.
Thanx
Thanx
