Stock cam vs performance cam
Old Aug 5, 2002 | 06:29 AM
spiceisler's Avatar
Default Stock cam vs performance cam
When you turbo a stock motor, why do some people re-install the stock cam? Wouldn't you make more power if you keep the perf cam?
Confused!
Old Aug 8, 2002 | 10:28 AM
Tiamat-blue's Avatar
Default Re: Stock cam vs performance cam (clean90Si)
I assume it would be because the performance cam is for N/A engines. Different things are happening in there with forced induction.
Old Aug 8, 2002 | 10:31 AM
CovertFI's Avatar
Confused!
an N/A cam has over lap. a performance N/A cam has ever more over lap. over lap is when bothe exhaust valves and intake valves are open at the same time. so with a turboed car the air would just move straight throught the engine.
Old Aug 8, 2002 | 10:41 AM
*Boostwerks*'s Avatar
Default Re: Stock cam vs performance cam (CovertFI)
Confused!
That is the same reason it is not very effective to FI a 2 stroke motor.
The air enters the engine the same time the spent exhaust is leaving.
[Modified by Bryson, 12:42 PM 8/8/2002]
Old Aug 8, 2002 | 10:44 AM
VTC_CiViC's Avatar
Your stock cam will do fine with boost. Idealy, you want a cam with more lift and less overlap/duration to prevent boost from escaping the combustion chamber, this is where aftermarket turbo cams come into play. Crower makes a *supposedly* very good turbo cam for SOHC's, look them up.
Old Aug 8, 2002 | 10:50 AM
poison's Avatar
very well said
there are turbo performance cams though with about the same N/A intake cam and the exhaust cam having alot of lift but very short duration while closing -- thus getting rid of alot of the overlap so air doesn't go right thru the engine.
[Modified by poison, 12:51 PM 8/8/2002]
Old Aug 8, 2002 | 10:58 AM
Urban Business
Guest
Posts: n/a
Default Re: Stock cam vs performance cam (poison)
yeppers, high lift low duration = turbo, low lift high duration = NA
demented132004
Acura TL, RL & ZDX
Feb 4, 2005 04:17 PM
knxtnh22accord
Jan 10, 2005 09:11 PM
