Need tips to hang exhasut higher
Old Jan 1, 2009 | 12:06 PM
chrimy90cx's Avatar
Default Need tips to hang exhasut higher
I have a 90 hatch. Stock exhaust and im hitting everything. I dont want to raise my car. Anyone have any tips to get the muffler off the ground lol.
Old Jan 1, 2009 | 12:37 PM
acmoc's Avatar
Default Re: Need tips to hang exhasut higher
Bend the hanger using a crow bar.
I lowered mine so it wouldn't hit my floor pan (mad lots of noise)
It works. Bend the one on the muffler or the car, You can also use a shorter bushing thing
Old Jan 1, 2009 | 12:44 PM
93formula's Avatar
we had a customer who ingeniously used hose clamps, the ones with screws from home depot, wrapped those around the rubber hangers and tightened them up so his exhaust would not hang low, his exhaust was tucked up real nice on his accord, you may want to try that, he claimed he gained about 1-1.5" of clearance..
Old Jan 1, 2009 | 12:53 PM
acmoc's Avatar
Oh, like a screw type hose clamp rapped around the rubber, and tight so it's at it's position as if their was no weight on it?
fireant's Avatar
This will fix it:
Old Jan 1, 2009 | 01:24 PM
93formula's Avatar
yup thats what this one guy had on his accord and it worked great, he was also slammed on full coilovers and there was no bottoming out issues when we took it for a test drive after the h22 trans swap. its cheap give it a try and see if that helps.
Old Jan 1, 2009 | 02:09 PM
chrimy90cx's Avatar
I will try that hose clamp one out!
thanks
Old Jan 1, 2009 | 03:30 PM
ArtyG's Avatar
I used hose clamps on my rubber hangers as everyone else above said to gain some extra ground clearance on mine, and it worked fine...just had to check occassionally to make sure they stayed in place.
swizz977
11
Aug 13, 2010 08:10 AM
steve96accord
Mar 15, 2006 09:39 PM
nitrousrush
Apr 17, 2004 07:35 AM
accord972002
Dec 30, 2001 04:13 PM
TypeR0207
Aug 22, 2001 04:25 PM
