exhaust hanger holes are too big too loose keeps falling off help
so i got some bigger exhaust hangers so my muffler wouldnt hit the bumper but the holes are too big is there anyway i can get it on there tighter?
Re: exhaust hanger holes are too big too loose keeps falling off help
get in the ghetto fab mindset! use spare bolt and washers and see if you can make it happen, or just bend the hanger 90 degrees after it exits the rubber hanger. hose clamp hanger to hanger? with some ingenuity, you and the hardware store can make it happen.
i want it to be really tight fit i was thinkin about putting duct tape around the hangers or silicone inside the holes idk
what do u think there gonna do at the muffler shop i dont want anything welded on i paid a lot of money for this exhaust and if i every want to put it on another car..
here's a though, drill a small hole through the middle of the metal hanger. install on car. then feed a keyring loop through the whole to act as a cotter pin. not ghetto, easy to remove, gets the job done, and you can hang stuff from it too.
Former Moderator
A couple of screw-type small hose clamps around the rubber hangers?
Well if you paid a lot of money for an exhaust, and it doesn't fit worth a crap then you need to figure out if the exhaust is the problem, or if your car is the problem.
Every time I've paid "a lot of money" for an exhaust it fit 100% perfectly with no issues at all.
Also cutting your bumper to fit an exhaust sounds really sketchy. What year/make/model car do you have, and what brand exhaust is it?
Get a piece of threaded rod to weld to the exhaust and bend it to fit your exhaust. then put a washer and nut on the end. removeable and not as badly hacked together
Shaguar47
05-11-2006 05:59 PM
