rear disc conversion on my 97 civic HX?????
Old Dec 31, 2008 | 06:36 PM
d-series guy's Avatar
Default rear disc conversion on my 97 civic HX?????
does anyone know how to do a rear disk conversion? i want to do it for my civic but dont know how, and dont know how much it costs. can anyone help me out?
Old Dec 31, 2008 | 06:43 PM
Unseen Racer's Avatar
Default Re: rear disc conversion on my 97 civic HX?????
dude please search. there are MANY posts and threads on D.I.Y about rear disks conversion
Old Dec 31, 2008 | 09:20 PM
Bob Dole!'s Avatar
Well first off you'll need trailing arms. You can just swap hubs, but I personally think its easier to just change out the trailing arms. Every 92-00 civic and 94-01 integra trailing arm is the same. The differance is the hub. All rear disc brake are all the same size as well (except type r). Second you'll need e brake cables. Since you have an hx, 99-00 si cables would be the best fit (although I'm told you can use Integra ones). You'll also need disc brake lines, pads and rotors obviously.
Old Dec 31, 2008 | 09:36 PM
zoniebutt's Avatar
i had an HX and did this... i got my whole trailing arms from an integra usually they sell for about 150... just un bolt ur whole trailing arm and follow ur ebrake cables they lead in under ur car by ur arm rest... remove ur arm rest un latch them and ull them through... its basically follow every thing u un bolt and repeat when installing then bleed ur brakes and ur good to go... the brakes will feel alittle softer until u upgrade i forgot the name of it but it goes under ur hood where all the brake lines meet u need to get it from a SI but they will work with out it i rocked mine with out it..
just try to get a complete trailing arm with e brake cables and brake lines so u dont gotta have ur self a headache to mix and match
Old Jan 1, 2009 | 06:37 AM
fly_high_gsr's Avatar
Also get Si prop valve to get good pressure front and back or else u'r just waisting u'r time with it cuz ex got drums less pressures on rear and more on front, with Si u get all four same amount of pressure.
CORRECT ME IF I'M WRONG.
Old Jan 1, 2009 | 07:07 AM
philosofy1's Avatar
doing this swap is easy, getting the trailing arm setup is alot easier vs. swapping hubs out.
other than the trailing arms, rear brake (disc) hoses, pads, and rotors.
also, if the arms you get have bad bushings i recommend you replace before installing.
there is a DIY thread somewhere, hit up the search forum.
94EG8's Avatar
Seagull Management
If you're buying the prop valve used its a lot easier to just get one from a CX/DX hatch, same part number as the Si.
Old Jan 1, 2009 | 07:17 AM
No its not Si has different part number, b4 i bought IT, i searched it and cx and dx still comeS with rear drums only 92 si hatch came with rear disc factory.
Here part numbers
220588 004 1 VALVE ASSY., PROPORTIONING 00 CIVIC EX
220473 004 1 VALVE ASSY., PROPORTIONING 00 CIVIC SI
Old Jan 1, 2009 | 07:20 AM
94EG8's Avatar
Seagull Management
For '92 - '95 yes, they are different, but for '96 - '00 CX, DX and Si all share the same part number.
Edit, I know the EX is a different part number, so is the DX/LX sedan.
Here are the part numbers from majestic honda:
CX hatchback 220473 004 1 VALVE ASSY., PROPORTIONING
DX Hatchback 220473 004 1 VALVE ASSY., PROPORTIONING
Si Coupe 220473 004 1 VALVE ASSY., PROPORTIONING
LX Sedan 220226 005 1 VALVE ASSY., PROPORTIONING
EX (non ABS) 220588 004 1 VALVE ASSY., PROPORTIONING
Old Jan 1, 2009 | 07:28 AM
Ok u'r rite dude i just checked and dey all same part number except my god damn car lol so i had to change it no hard feelings
Old Jan 1, 2009 | 08:01 AM
DumpedSi's Avatar
i have some rear disc for sale. I sent you a private message
boostitalready
Nov 25, 2012 04:36 PM
CLE
Feb 22, 2006 07:30 PM
turbob16a522
Jun 22, 2005 03:46 PM
BeeEK9R
May 25, 2005 12:16 PM
MugenHonda
Jun 12, 2003 05:14 PM
