Y8 fuel rail on A6 head?
Old Dec 31, 2008 | 06:22 PM
puertoricanboy90's Avatar
Icon6 Y8 fuel rail on A6 head?
I just replaced the fuel pump on my 88 CRX Si and i still have issues with it starting. Once the car gets going and the fuel pressure builds i don't have issues, but it takes a while to kick over and runs so lean that i can't drive it until the car smells like its running rich. Over the number three and four cylinder, i see some residue coating the injectors and fuel rail. So i'm assuming that i have a small leak from either the rail or injector (the residue smells like gas). I have ruled out leaks in fuel lines b/c i did a thorough inspection once the tank was off. Could i possibly place a Y8 fuel rail with injectors and fpr in lieu of the A6 one's i have now? Would they fit properly? Would i need a diff wiring harness? etc? Any help or advice would be appreciated. Thanks
Old Jan 1, 2009 | 11:36 PM
Default Re: Y8 fuel rail on A6 head?
bump. help please
Old Jan 1, 2009 | 11:38 PM
EFstyle's Avatar
the y8 rail will not fit on the a6 manifold, at least without out a bit of modification... the y8 injectors also will not work properly...
Old Jan 2, 2009 | 04:25 PM
would i need to tune the ecu for them to run properly or just change the wiring harness? would putting a Y8 mani instead of just the rail allow me to fix the issue?
MUGENVX9
Honda Civic (2001 - 2005)
Aug 9, 2013 10:59 AM
lowridincivic92
Feb 14, 2006 10:08 PM
ek9child
Dec 14, 2005 01:54 PM
CivicSiRracer69
May 16, 2004 12:03 PM
KamikazeRacinz
Apr 22, 2004 06:56 AM
