Clicking when turning?????
Old Dec 31, 2008 | 02:57 PM
blue93civic's Avatar
Default Clicking when turning?????
Hello all,
I've got a 93 civic Ex sedan. When I turn to the right the front driver side tire starts to click very loudly (just started). I was driving it home today and I couldn't hardly keep it on the road. One moment it would be just fine and the next it would pull really hard to the right for a few seconds, then there would be a cluncking or binding noise and the car would right itself and drive fine - then repeat. The axle boot on that side seems fine and I checked the inner tie rod and it seemed fine as well (replaced it last year). I also lifted the car up and spun the wheels by hand to see if I could feel any binding - nothing. My rack and pinion is leaking and there is some play (side-to-side) in my tires so I am wondering if that could be the problem. I'm not against replacing the rack and pinion but if I am missing something I would really like to know about it.
Any help would really be appreciated, thanks
Dan
Old Dec 31, 2008 | 03:34 PM
91blackEF's Avatar
Default Re: Clicking when turning?????
check your axels
Old Dec 31, 2008 | 03:36 PM
Shane Camp's Avatar
yeah -- turn the wheel to lock in one direction then check the axel for spilts in the boot. then do the other side. it's possible the axel cv joint has failed without a busted boot.
Old Dec 31, 2008 | 03:44 PM
Unseen Racer's Avatar
its your axles. the rubber part that holds in the grease is busted.
you gotta but a new axle.
u believe its called the CV join
Old Dec 31, 2008 | 03:46 PM
Hondatypr636's Avatar
Ya most likely a CV joint. Don't wait to long cause my clicked for a few days then broke in 3 pieces.
Old Dec 31, 2008 | 03:47 PM
No VDUBS here in206's Avatar
your cv axles are busted, they've worn down to the point that they slip but only when its in a turn, replace the whole thing, buy duralast from auto-zone, they're lifetime warenty
Old Dec 31, 2008 | 03:48 PM
dude are you serious?
mine have been doing that for about a year now. im too broke to buy a new one. and its been running fine
Old Dec 31, 2008 | 08:31 PM
hondafab19's Avatar
its most likely your axle which one is
for you to determine , but sounds like
it...be careful and dont drive on it
like that too long...
Old Dec 31, 2008 | 08:47 PM
b18cyacrx's Avatar
Banned
Change your axles and ONLY use OEM Honda. Anything else is longer in length and doesn't have the rubber damper on them. You will get a vibration while accelerating using cheap aftermarket axles.
Old Dec 31, 2008 | 08:49 PM
b18cyacrx's Avatar
Banned
Don't be stupid like this guy unless you want to break or wear out other parts on your car too.
Old Jan 1, 2009 | 08:31 AM
hey guys,
thanks for the info, here is an update:
I thought the noise was coming from the driver side, but when I asked my wife she said it was coming from the passenger side - checked the boot and sure enough torn wide open (I did check the driver side earlier but it didn't even occur to me at the time to check the other side). I've got a half-shaft on hold at autozone and I'm pulling the old axle right now. I will let you now how it turns out.
Thanks again for your help.
Dan
egjake
Jan 3, 2010 07:18 PM
Slosc2
Apr 4, 2009 06:20 PM
traitorzxiong
Dec 1, 2005 06:44 PM
penney
Mar 5, 2005 03:29 PM
cheetah64
Oct 4, 2004 03:58 PM
