Rear brake question.
Old Aug 5, 2002 | 01:49 AM
COREY ITR#625's Avatar
Default Rear brake question.
I have a 93' CX with drums. As most of you should know that. Anyways, I have a chance to buy front and rear brakes off a 95' Si for $100. Are the front Si brakes bigger than the CX front brakes. I have cross drilled rotors on the front and I don't want to get rid of them if they are the same size. If they are the same size I'm just gonna try to buy the rears.
Thanks! Corey
Old Aug 5, 2002 | 03:44 AM
shawnhayes's Avatar
Default Re: Rear brake question. (COREY ITR#625)
Thanks! Corey
95 Si's have bigger front brakes, but you will need the steering knuckles to fit the calipers and rotors. The calipers are the Nissin calipers, as opposed to the Akebono calipers on the CX, and they have different mounting points for the caliper.
Shawn
Old Aug 5, 2002 | 05:58 AM
Takeoff's Avatar
Default Re: Rear brake question. (shawnhayes)
Buy both front and back. They are bigger and better. Just make sure you get the whole assembly. The knuckle and everything attached in front. The trailing arm and everything attached in the rear.
Old Aug 5, 2002 | 12:36 PM
Default Re: Rear brake question. (Takeoff)
If the steering knuckles and rear trailing arms aren't there, would it still be worth buying for $100? I could always find that stuff later of just buy them new couldn't I? Or would it be too expensive?
Thanks
aquabob89
16
Jul 6, 2008 06:45 PM
DjKid765
Apr 18, 2008 06:49 AM
onefastx
Feb 5, 2006 02:02 PM
northkai3
Aug 12, 2005 10:36 AM
MrTodd
12
Nov 4, 2004 07:59 PM
