93 EG6 B16 axle question
I have a 93 SI hatch with a B16a swap, I bought the car with the swap already done, and i'm in the process of replacing my driver side axle. I was wondering what axle would I need to buy to replace it.
Depends on what intermediate shaft was used, if it was a cable intermediate shaft then '90 - '93 integra axle, it was a hydro intermediate shaft (more likely) '94 - '01 integra/'94 - '97 Del Sol Vtec/'99 - '00 Civic Si axle. Note that you can use a cable intermediate shaft and axles on hydro tranny and vice versa, although it does require replacing the drivers side axle seal. (I think the passengers side uses the same seal in both cases, but I could be wrong on that point)
Do you have ABS? If so just go get the axles for a 2000 civic Si to make it easy.
EDIT: Oops!!! you do have ABS!!
Edit, I may have been wrong in which intermediate shaft had which end, but the point is one has a male end and one has a female end.
Jwbetley
Jul 18, 2009 04:36 PM
CIVIC TYPE R 52
Feb 16, 2003 08:41 PM
