88 CRX build thread (56k warning)
Old Dec 31, 2008 | 11:28 AM
93formula's Avatar
Default 88 CRX build thread (56k warning)
well since a buddy on here has created some buzz with his eg build thread; https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/my-eg-build-thread-56k-warning-2456645/, ive decided to post one of my projects up on here as well.
the car is a 88 crx si, with 120k original kms on the odometer, we got the car for 200.00 three years ago. was previously owned by a lady that did not change the timing belt and of course at 120k it promptly let go. there was no damage to the valvetrain so the original plan was to replace the belt and sell the car, it had slight damage to the passenger fender and door at the time.
over the course of time i had some friends that wanted to buy the car so giving them the friend price i took deposits and well they never panned out, one of them actually went to the trouble of disasembling the car because he had pipe dreams and spray painted the car when he and some buddies were drunk, which you will see in the later pics.
currently i have been able to garner some sponsors for the car and aquired free body and paint work from a local shop.
the car when we first got it:
Old Dec 31, 2008 | 11:30 AM
93formula's Avatar
Default Re: 88 CRX build thread (56k warning)
the rear tray was damaged and has since been replaced by another unit.
Old Dec 31, 2008 | 11:33 AM
93formula's Avatar
the car after a buddy decided he was going to paint the car flat black.... he had removed the front clip and interior to strip the car down so it would be light wieght, well the front clip because he wanted to do the colour change but you get the idea..
interior was left in shambles, it has since been replaced back to its former glory. this pic was taken half way of putting it all back together..
Old Dec 31, 2008 | 11:37 AM
93formula's Avatar
its got a b18a out of a 92 teg, it was installed all half assed by my brother in law who has since been reprimanded and stripped of his civic for stupidity... we have also corrected the install/wiring and runs like a champ.
Old Dec 31, 2008 | 11:47 AM
93formula's Avatar
suspension consists of tokico illumina's, ground control sleeves, DA front/rear brake swap, brembo x drilled/slotted rotors, stainless steel brake lines, DOT5 brake fluid, energy suspension bushings throughout, megan racing rear lower tie bar, generic front strut bar, obx rear camber kit, and ingalls front camber kit. we originally used the aim industries front upper adjustable control arm, but it sat on the frame rail even with notching and the fender gap being just over two fingers with 15" wheels, so we pulled them off and used a stock upper control arm with an ingalls camber kit and now it only hits the frame rail on big bumps, ive come to the conclusion that the DA knuckles are taller and that may be causing an issue...maybe someone has an opinion on this issue....
the fenders were replaced because we needed the passenger fender and found a cheap set with the side markers already installed.
Old Dec 31, 2008 | 11:52 AM
93formula's Avatar
the car is now at body and paint at crush collision, its too bad we were not able to snap pics of the body work that went into the car, but all the rust was removed and new metal was welded in.
the primer just went on yesterday, and hope to see some paint samples today if i have time, hopefully it will be completed and back by friday/monday.
the plan is to sell the b18 out of it as a running swap, we have a b18b and a b16a sitting aroud collecting dust that will also go in to sell as running swaps.
i have a d16a6 with 130k kms for which i have a jrsc which i will throw on and use for autocrossing/road racing while i build up a d16 turbo with the vitara pistons and eagle rods i have kicking around, that will be the final engine choice for this vehicle, thanks for taking the time to look guys! and good luck with all your builds!!!
Old Dec 31, 2008 | 02:35 PM
cvcdx's Avatar
***cage it***ha ha just kidding... not... I christen thee Epic "Race" i would like mine to be "Style"... relo could rock "Big Dog" for his monster motor/turbo all custom build for the skyline and "Daddy" for the firebird 'cause what else would you call a car capable of 1000 horse power?.. exactly
Old Dec 31, 2008 | 02:49 PM
harmonator84's Avatar
Wow your "buddies" are really stupid! Really damaged a good stock y49.
Old Dec 31, 2008 | 03:29 PM
93formula's Avatar
yeah tell me about it, complete morons....did nothing but damage and waste time...
as for "race" i dunno, it will deffinately do the AX, but i wont be doing the stripped interior in this one, i like the condition its in, maybe another one....as for track we shall see when the turbo d goes back in.
BTW just got back from the body shop, the had done the door jambs and under the hood, looks good but stupid me forgot the camera, D'oh!!
Old Dec 31, 2008 | 10:49 PM
kess's Avatar
If you ever want to get rid of that JRSC for a D16A6 i would be interested...
Old Dec 31, 2008 | 10:54 PM
93formula's Avatar
it will be up for sale, but i wanted to sell it locally with the motor after i had it up and running, but pm me an offer i may be interested its got dsm 450's.
Old Jan 2, 2009 | 01:56 PM
93formula's Avatar
Just got back from the paint shop, the door jambs were done and under hood, and checked out the paint samples...
Old Jan 2, 2009 | 03:03 PM
kojack_0's Avatar
good stuff. wanna see more updates.
Old Jan 2, 2009 | 03:49 PM
93formula's Avatar
thanks i was hoping to have it back this fri but it looks like next week now before i will get it back...
Old Jan 3, 2009 | 01:24 PM
relo's Avatar
all the hassel i went through to put that thing back together is now worth it its sexy
Old Jan 3, 2009 | 03:16 PM
txihondatec's Avatar
i have a similar setup jus for now.What kind of lip is that in the front?
Old Jan 3, 2009 | 04:23 PM
ef9_b20's Avatar
its stock on the 88 models.
looking good bro
Old Jan 3, 2009 | 04:34 PM
93formula's Avatar
thanks, its actually a vw lip, the center has been molded to look like one piece.
Old Jan 4, 2009 | 11:50 AM
relo's Avatar
that lip was alot of fun
Old Jan 7, 2009 | 01:39 PM
93formula's Avatar
just got back fromt he body shop, car is almost done and back together....
the pics make it look shinnier then it is, the colour is satin black...
Old Jan 12, 2009 | 01:10 PM
93formula's Avatar
car is a little more together now, the hood is getting done today, should have it back in my hands tommorow or the next day, here are some teaser pics with the wheels on, sorry for the dusty pics forgot to clean the lens and it was kinda cramped in there so i couldnt get further pics....
Old Jan 12, 2009 | 01:16 PM
93formula's Avatar
the white was done on the center of the hood, one to be different, two in tradition of a former car we built, and three as a means of being able to disply our sponsors decals. heres a former car which is missed....
Old Jan 12, 2009 | 01:19 PM
DTA-Zombie's Avatar
sexy - looks so good
Old Jan 12, 2009 | 09:26 PM
relo's Avatar
sorry ry i like the old paint sceem better
Old Jan 12, 2009 | 09:45 PM
93formula's Avatar
huh? yellow with black spray painted flames???LOL
