Turbo water return lines?...Top or Bottom
Old Dec 31, 2008 | 08:04 AM
srmofo's Avatar
Default Turbo water return lines?...Top or Bottom
Like it says.....do you return your water from the turbo to the top or bottom of the radiator?
....Yes I saw the post about this and thought it would make a good discussion.
personally, mine is mounted at the top, because that's where the rest of the coolant returns at.....what about everyone else?
Old Dec 31, 2008 | 08:15 AM
B R Fittings's Avatar
Default Re: Turbo water return lines?...Top or Bottom
You can use the top or bottom for the return. Although the top would be best since the radiator cools from the top down. I doubt there would be a significant difference if you were to test the two different ways though. The amount of cooled coolant coming down from the radiator is significantly more then whats coming from the turbo.
chrisfromsrq
Oct 2, 2009 08:24 AM
b20forlife
May 14, 2009 05:11 AM
pendejon
Jan 19, 2006 08:52 AM
bambam
Apr 13, 2005 02:21 PM
