stick car with automatic ECU?
Old Dec 31, 2008 | 07:05 AM
QBANBOY407's Avatar
Icon6 stick car with automatic ECU?
well i have a automatic ECU but my car doesnt wanna move.
it is a d15b7 and the ECU is p06 which is the automatic 1.
Old Dec 31, 2008 | 07:22 AM
esean93's Avatar
Default Re: stick car with automatic ECU?
what do u mean by it doesnt wanna move?it doesnt shift or the motor doesnt even rev?i think it should run but it might just have a cel for a auto tranny code.
Old Dec 31, 2008 | 07:25 AM
andoxviii's Avatar
Most of us buy standard ECUs for standard cars for a reason.
Are you throwing any check engine lights?
Old Dec 31, 2008 | 07:31 AM
QBANBOY407's Avatar
i dont know how to check the engine codes but it is a d15b7 with a y5 transmission. and i put the car in gears but it doesnt move. some1 told me is not the ECU so i dont know what could it be!
QBANBOY407's Avatar
is the stock ECU that comes with the d15b7 (p06) but the car used to be in a diff. shell which was automatic so i put it in my new shell with a standard tranny. it just dont wanna move even when i put it in gears!!
Old Dec 31, 2008 | 07:32 AM
QBANBOY407's Avatar
well it REVS til 3k RPMs but maybe you are right!
Old Dec 31, 2008 | 07:33 AM
andoxviii's Avatar
This means the ECU is in "limp mode". It wants your attention on the check engine lights and only revs to 3000 rpm to avoid problems with the engine.
Old Dec 31, 2008 | 07:37 AM
QBANBOY407's Avatar
ohhh!!! so what should i do? and yes i have the check engine on!
Old Dec 31, 2008 | 07:38 AM
esean93's Avatar
i have a manual d15b7 ecu.pmed
Old Dec 31, 2008 | 08:11 AM
QBANBOY407's Avatar
any1??
zeplin's Avatar
You should get a manual ECU, good to see a guy has one! I've heard that using an auto ECU will only make it idle high and throw a CEL, but it's most likely in limp mode as andoxviii has said. Your best bet is to purchase a standard ECU and go from there.
Old Dec 31, 2008 | 08:17 AM
QBANBOY407's Avatar
thanks sir i appreciate it
Old Dec 31, 2008 | 08:51 AM
94EG8's Avatar
Seagull Management
In any case having an automatic ECU will not cause the vehicle to not move. Thats an axle/clutch/transmission problem. The easiest thing to check is that axles are seated properly in the transmission. When you put it in gear and let the clutch out does the speedometer move? If so its most likely an axle issue, if not its more likely a clutch or transmission isssue. You can very easily convert a manual USDM OBD1 automatic ECU to a manual btw, as shown in the picture below.
Old Dec 31, 2008 | 10:17 AM
QBANBOY407's Avatar
so i just checked and both axles are not all the way in. i tried to make them go all the way in but i couldnt, idk why.
ps: whats a JUMPER WIRE???
Old Dec 31, 2008 | 10:34 AM
94EG8's Avatar
Seagull Management
Pull them out a bit and try giving them a a sharp push, they should pop right in.
Its just a piece of wire (usually for something like this you cut the leg of a resistor or use a piece of 22 gauge solid telephone wire) that connects one point to another on the board
Old Dec 31, 2008 | 10:36 AM
QBANBOY407's Avatar
im going to try that. and what i do is i connect rp-17 with rp-18 with a piece of cable right?
Old Dec 31, 2008 | 10:41 AM
94EG8's Avatar
Seagull Management
No, you want to remove both resistors (RP17 and RP18) and the connect the 2 solder points on the board where RP18 went with a small piece of wire. Basically replace the RP18 resistor with a solid piece of wire, for RP17 simply remove the resistor.
nub's Avatar
nub
To get the axle all the way in takes a quick jabbing motion to get the retaining ring to seat. The jumper is a short conductive lead used to bridge a circuit. You need to remove the resistors in positions RP17 & RP18 and replacing RP18 with a wire jumper.
Old Dec 31, 2008 | 10:43 AM
QBANBOY407's Avatar
ok i got it! now i understand lol
Old Jan 1, 2009 | 01:06 PM
esean93's Avatar
to push the axle in.park(push lol) ur car beside a wall and use it as a support and push it with all u got.
max_man4945
May 21, 2010 09:26 PM
schillshak
Feb 1, 2010 11:14 AM
JDM96SpecCTR
Nov 12, 2004 08:57 PM
Styler93GSX
Feb 2, 2004 03:28 PM
AsiAnVenOm
Jun 3, 2003 09:37 PM
