How to unscrew torx screw from steering wheel?
Old Dec 31, 2008 | 04:52 AM
SHG_Claudio's Avatar
Default How to unscrew torx screw from steering wheel?
Theres this junked civic at the junkyard that I want to get the steering wheel off of. However there is a torx screw in there that I simply cannot unscrew, I went and bought a T30 torx screwdriver and it was impossible to unscrew it, even with both hands. All I managed to do was strip the bolt a little, the steering wheel is locked so the bolt is facing up so between the windshield and the steering wheel, there really isnt much space.
What can I do to get it off? Keep in mind its a little stripped, not baaaaaaad, but its def now new. The other one on the other side hasnt been touched. Thanks in advance.
Heres a picture of the bolt Im talking about:
Old Dec 31, 2008 | 05:03 AM
SPOOLINmatt's Avatar
Default Re: How to unscrew torx screw from steering wheel?
snap some vice grips on the torx driver you are using, your best bet is probably going to be an impact screwdriver with that torx bit in it. Last resort is easy, you drill it off and replace it.
Old Dec 31, 2008 | 05:37 AM
EcivicG's Avatar
no no no....i had the same idea as you and thought it would come off pretty easy.
just go to autozone and pick up a T30 1/4in socket (should only be like 3 bucks max for a cheapo great neck piece, but your not using it often), and throw an extension on your ratchet and it should come off prety easily.
Old Dec 31, 2008 | 05:50 AM
That sounds like a good idea, i have a ratchet so ill put on my extension and try that socket. Thanks guys
Old Dec 31, 2008 | 05:59 AM
3rdman's Avatar
or eat a good breakfast before you go back to the bone yard and put some elbow grease into it : )
Old Dec 31, 2008 | 06:11 AM
CIREf8's Avatar
i'd drill it but im not sure if that what damage anything though
Old Dec 31, 2008 | 07:54 AM
DTA-Zombie's Avatar
I have some different ones - I got the folding one so I have a handle and can 90 degree it - works great
Old Dec 31, 2008 | 07:57 AM
QBANBOY407's Avatar
what he said ^^^
ceezo70's Avatar
brute strength will work...
but a smart person will us the ratchet with the extension...itll be fast and easy
Old Dec 31, 2008 | 08:16 AM
Allright Ill try those suggestions, thanks.
Old Dec 31, 2008 | 09:45 AM
i forgot about a socket, yeah you cant go wrong with that.
Old Dec 31, 2008 | 10:13 AM
93preludeh22's Avatar
Is the airbag deployed? Be careful..
Old Dec 31, 2008 | 10:20 AM
Nah the airbag is still there, the whole car looks fine too lol. It wasnt an accident or theft, i think the engine took a **** or something. The airbag is still inside weeks ago i was there and i disconnected the airbag plug and the battery isnt connected either, ill be ok, good looking out!
Old Dec 31, 2008 | 10:40 AM
teamworxek9's Avatar
Get a socket like said up there and use a impact driver. You pre load it then hit it and it will snap it loose. The impact driver will come in handy when you are removing set screws in your rotors, so now youll have one.
Old Dec 31, 2008 | 12:32 PM
I was working at a dealership a few years ago and they were blowing up air bags.. kind of powerful
I'm afraid of them completely
Old Dec 31, 2008 | 12:37 PM
EcivicG's Avatar
^^ you know! that ish looks like it would kill you not save your life, but they do save lives.
ohsojdmdc
Nov 10, 2009 06:33 AM
dustin_crxsi
Oct 30, 2006 05:29 PM
mykal
16
Oct 2, 2004 01:41 PM
Bandit74
15
Sep 17, 2004 09:36 PM
KK
Jul 10, 2001 02:40 PM
