Datalogging AFR w/ an AEM wb and Freelog.
Old Dec 30, 2008 | 11:18 PM
Alpinestar03's Avatar
Default Datalogging AFR w/ an AEM wb and Freelog.
Im going to be using the free version of crome along with freelog to learn how to tune my car. Ive been researching on PGMFI for the last three months and have been learning alot. I purchased the Moates HULOG and plan to premantly install it in my car along with my AEM UEGO wideband. I understand that my WB has a 0-5v output for the signal and that my ecu will only read up to 0-3.85v. I dont think i can adjust the output on my WB like the LC-1'S.
I was wondering if instead of my hooking my signal wire up to D14, would i be able to wire the signal wire to the corresponding wbo2 wire on the datalogging cable? Or does the ECU need to translate the information? I figured it would have a broader spectrum of data with it being able to read more than just 3.85v.
Ive also heard that you can modify the ecu to read up to 5v signals. But I would have to use my WB02 for my ecu to use it in closed loop? And wouldnt that eliminate the need for my NBo2?
Im not shure if this is a better way of doing it or not.
I would appreciate all insight! Id hate to get rid of my brand new Wideband for another one..
Old Dec 31, 2008 | 06:13 PM
kicked25th's Avatar
Default Re: Datalogging AFR w/ an AEM wb and Freelog.
You CAN modify the output signal, if you read the manual. However after talking to Xenocron, he said the superlean values between 3.8 and 5 wont be used much anyway, so to just use D14. However, I have heard from a number of individuals that AEM and Freelog even with the values setup correctly logs incorrect values.
Old Jan 1, 2009 | 08:54 AM
drewbie57's Avatar
I have used Freelog to datalog my wideband many times and have found the data to be useful and accurate.
The mod that allows you to monitor voltages up to 5V isn't as beneficial for monitoring the lean AFR voltages from 3.85V to 5.00V, the mod is a low pass filter that eliminates a large amount of (high frequency) noise on the signal. I still recommend doing this mod for people that use Crome Pro or Freelog to monitor the voltage from a wideband. I honestly don't know about other ECU tuning software programs though.
I will post the helpful links for doing the "5V Wideband" ECU modifications and setting them up properly in the software.
http://forum.pgmfi.org/viewtopic.php...a&hilit=5v+mod
siguy2k
Engine Management and Tuning
Apr 10, 2022 12:51 PM
Egalltheway
Jun 18, 2014 08:11 AM
bcumbie
Mar 16, 2012 08:49 PM
iiilgsrlll
Sep 25, 2004 11:49 PM
