EG traction bar..rage racing header..Bseries stuff 626/818
traction bar made by jason from rage racing... comes with mounting brackets as well...200
rage racing 4/2/1 longtube header...stainless steel...has dents on the bottom...but i will fix it for the who ever buys it...missing two springs for the slip collector, but i believe whitfiels replaces them for free since it was an issue with them breaking...300
b series hydro clutch...hyper pressure plate with act 6 puck sprung disc...has light discoloration, but still in great shape....i resurfaced the pressure plate and put in a brand new disc very shortly before i took the car apart...entire assembly has very low miles..SOLD
2 vtec solenoids...the other one has a billet solenoid cap... 25 and 30
half radiator with fan assembly- 50
driver side axle and intermediate shaft ...axle for b series into EG...inter for hydro B series- 30 each
oem anodized billet spark plug wire cover for b series -30
2 sce copper exhaust manifold gaskets..one for b series one for d series - 15 each
str fuel rail...polished billet aluminum...comes with banjo bolt and fuel line - 80
oem polished billet oil cap - 20
both can be seen in this pic
i also have, but no pics till tomorrow...
special edition innovative bronze anodized billet aluminum poly engine mounts for b series into EG chassis...less than 2k miles on them- SOLD
4 stock bseries injectors-240cc - 20
iacv- 20
hondata insulated intake manifold gasket - 20
bare b series head with rocker assembly and LMA, brand new oem guides and viton seals...comes w/ mugen thermo and sensors...also cam caps and all bolts - 150
generic 3 inch intake arm w/ filter - 10
brand new stealth performance lsvtec steel braided oil line - 30
great condition used 81.5mm je pistons pressed on brand new oem b18 LS rods that have had the flash lines polished off as well as have been shotpeened and big ends resized for arp rod bolts...this piston/rod assembly has not been run yet...only pistons are slightly used...rods are brand new from dealer... comes with the rod bolts - 200
b18 crank with fresh micropolish - SOLD
b18 block...freshly decked block as well as fresh bore and hone...cylinder wall was scored during assembly...81.5 now needs to go 81.75 to clean up...comes with main caps that have a fresh align hone done to them - 80
ef hatch tail lights w/ all red center garnish...all 3 for 50...clean
ef hatch headlights...i think i have two pairs - 40 pair
ef civic mechanical speedo cable - 20
throttle cable...ef i think...used it for b series swap - 15
new oem headgasket for ls/vtec setup - 30
uncut engine harness from 95 dx civic - 100
uncut body harness from 95 dx civic -100
msd blaster ignition coil - 20
wings west whale tail for ef hatch...rare -100
mugen mid wing for ef hatch- 50
oem rear bumper for 90-91 hatch...black never painted - great shape - 50
items and pics will be added as i find them...thanks
best way to reach me is on my cell phone.... 626 354 5526 - Shant
iacv- 20
Interested in
special edition innovative bronze anodized billet aluminum poly engine mounts for b series into EG chassis...less than 2k miles on them- 150
B series SCE Copper gasket $10
B series Half-Shaft
B series Half-Shaft
would like to see picture of the mounts? you're asking $200 for the traction bar and $150 for the mounts, so i was wondering if i can get them for $350 cash dropped off to san diego.
"traction bar made by jason from rage racing... comes with mounting brackets as well...200"
"special edition innovative bronze anodized billet aluminum poly engine mounts for b series into EG chassis...less than 2k miles on them- 150"
james111
Jan 7, 2007 04:30 AM
Weston
Dec 17, 2004 02:02 PM
