All D series water pump the same?
Old Dec 30, 2008 | 07:40 PM
hmtcrxsir's Avatar
Default All D series water pump the same?
I just wanted to know if all D series water pump are the same? Im worried that the guy at kragen may have given me a wrong water pump. I have a D15B7 engine and recently the water pump has gone bad. So I only wanted to replace that. But my question is the water pumps all compatible with one another? I heard only the D15 are compatible and not the D16z6 water pump. Well the water pump bolted right up but for some reason after installing the water pump the timing belt seems to be a bit tighter than I had it with the old water pump. Im not sure if it has an extra teeth or so on it making the belt tighter. It makes a really loud screeching sound when I start the car up and it starts to smoke real bad (like the timing belt is rubbing against something. Help?
Old Dec 30, 2008 | 08:00 PM
EFRue57's Avatar
Default Re: All D series water pump the same?
it's different.
d16z6 Honda part number - 19200-P08-004
d15b7 Honda part number - 19200-P10-A02
97_EX_in_NC
12
Mar 7, 2018 07:17 AM
B00sted Eg2
May 7, 2009 01:34 PM
Mr_Moos
Jun 24, 2007 10:04 PM
Raskal
Jan 27, 2005 07:01 AM
Volcom
Jan 23, 2002 10:31 AM
