any ideas???
Old Dec 30, 2008 | 05:03 PM
95eglshatch's Avatar
Default any ideas???
so here is thdeal i have a 95 eh hatch with an 95 ls swap and when i bought the car it needed a o2sensor and speed sensor when i went to hook up the o2 sensor no plug and same with the speed sensor.ok so not that big a deal ill just put a new harness then i find out it has the stock cx 1.5 ecu in it.so bought new ecu and harness. i put the harness in the car and no map sensor and i have a white plug that comes out of the harness next to the oil pressure sensor on the back of the block and i cant find a sensor for the plug to go into. i called the kid and he said that he gave me the wrong harness this one is for a civic he said i can pick up a ls one but have to drive 2 hrs to get it. what do u guys think i should do? sorry for the long post just trying to give u enough info thanks.
Old Dec 30, 2008 | 05:09 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: any ideas???
Why don't he just send it to you in the mail?? It's not that much.
Old Dec 30, 2008 | 05:12 PM
well i would have to give him this one back.is it easy to wire up a map sensor? what could the white plug be for?
Old Dec 30, 2008 | 05:17 PM
94EG8's Avatar
Seagull Management
The only real difference between a '95 LS harness and a '95 DX harness is that some of the wiring on the LS harness is longer. All the connectors are the same, if you got a CX harness then you will need to add 3 wires for the O2 sensor. The only white plug I can think of in that area is the the IAT sensor on the back of the intake manifold.
Old Dec 30, 2008 | 05:26 PM
well would the o2 sensor still plug in though cause it still plugs in to the plug on the harness.it might go on the intake i may not have seen the plug on the manifold.
Old Dec 31, 2008 | 12:41 PM
no one else has any ideas? please help got to get this thing fixed asap.
Old Jan 1, 2009 | 07:39 AM
bump it up.maybe i can get some help
justdoinme23
Jun 21, 2011 01:12 AM
sscivicsi
Mar 1, 2010 08:10 PM
95eglshatch
Jan 2, 2009 08:00 AM
B18CivicEH2
Sep 10, 2007 07:10 PM
