90 crx si mpfi?
Old Dec 30, 2008 | 04:46 PM
schock3's Avatar
Default 90 crx si mpfi?
is my crx si mpfi or dpfi?
Old Dec 30, 2008 | 04:52 PM
schock3's Avatar
Default Re: 90 crx si mpfi?
what obd1 dizzy am i going to need to switch to odb1 from odb0?
Old Dec 30, 2008 | 05:17 PM
EFRue57's Avatar
mpfi. 92-95 is obd1. so it depends on if you're staying d series or going b series. if staying with a d, then use a d series one, if you're going b, then use a b series one.
Old Dec 30, 2008 | 05:55 PM
schock3's Avatar
i have the b16a swap in there now. thats what i figured. its gunna be like 500 to switch to odb1 and mpfi
Old Dec 30, 2008 | 06:01 PM
sgallagher's Avatar
You're already mpfi.
To change to OBD1 you will need a distributor, 4 wire O2 sensor, jumper harness and an ecu.
If you are running the stock exhaust manifold you need to plug the holes where the O2 sensors are because they only sample from 2 cylinders each. You will need to add a bung for your O2 sensor after the collector or where all 4 cylinders meet.
EFb16aCRX
Dec 28, 2010 04:44 PM
skromee
Apr 27, 2010 01:36 AM
pentsas
Jan 19, 2009 03:55 PM
FakeJDMEF8
Jan 31, 2005 09:20 AM
EVOCELICA
Jul 9, 2004 01:10 PM
