Car won't start
Old Dec 30, 2008 | 03:22 PM
devin_hoang's Avatar
Default Car won't start
Today when i woke up my car started just fine and i drove it and turned it off then i tried to start it up it started up for like 2 seconds and then shut off. i tried to jump start it and push start it but it didnt work.
what should i check?
Old Dec 30, 2008 | 03:27 PM
arrocha87's Avatar
Default Re: Car won't start
is it cranking just not starting or nothing at all? it could be lots of thingas without more details... fuel pump, no spark, etc...
Old Dec 30, 2008 | 03:33 PM
its cranking but it wont start. usually when it happens i just jump start it but it isnt working this time.
Old Dec 30, 2008 | 03:40 PM
i just checked if it was sparking and it was sparking.
Old Dec 30, 2008 | 04:06 PM
arrocha87's Avatar
do u here ur fuel pump prime when u first turn the ignition on? sounds like ur not getting fuel if u have got spark and are cranking.
Old Dec 30, 2008 | 05:15 PM
oh i see. what would i need to check
Old Dec 30, 2008 | 06:05 PM
arrocha87's Avatar
well u hear ur pump priming when u turn ur ignition on. it sounds like a hum/vibration...
u could pull an injector out and see if its spraying....
Old Dec 30, 2008 | 09:28 PM
i dont hear the fuel pump
Old Dec 31, 2008 | 08:43 AM
anyone?
Old Dec 31, 2008 | 09:14 AM
Redline it.'s Avatar
My car wont also start. One night commuted from work farther than usual and drove the engine hard a bit. Parked it. Next morning it wont start.
There is spark, fuel on the plugs, rotor inside dizzy cap turns, cam gears line up, timing belt is tight, but theres one thing. I just did a compression test and the results are weird.
stock gsr swap with intake and exhaust in a 94 hatch
psi from dizzy to right cyls
140 , 125 , 175 , 150
some of them took more than a couple cranks to reach the max psi
175 was alot quicker than the others.
please help. only car i have.
i will also check the main relay.
Old Dec 31, 2008 | 03:25 PM
arrocha87's Avatar
Icon6 Re: Car won't start
check that your fuses arent blown. the ones inside the cabin...
Old Dec 31, 2008 | 06:01 PM
Christopherian1982's Avatar
What fuses and what relays do you speak of... I want to know as well?
JDM Freakk
Jun 21, 2011 05:36 PM
SsB_Db8
Apr 30, 2009 07:29 PM
vxnine
13
Sep 26, 2004 05:17 PM
Accord15
Jun 25, 2003 09:54 AM
nitroacc0rd
Mar 1, 2003 11:08 AM
