Ek, dc...oem & aftermarket parts...all must go!!!!!
Im attaching the full list of parts i currently have on hand. If u want pics...email me or pm me and i'll send em to you! Thnx!!! Happy honda-days! TONS OF PICS ADDED ON SECOND PAGE!!!! CHECK EM OUT!!!!
*** UPDATED WITH SOLD PARTS AND LOWERED PRICES***
PLEASE BUMP IF YOU VIEW THIS POST!! THNX!!!
FOR SALE
95 ACURA INTEGRA OEM PARTS:
95 JDM GSR TRANY W/ LSD $600
JDM GSR HEADER W/HEAT SHIELD $125
ABS COMPLETE (HARD LINES, PROP
VALVE, SENSORS, MODULE, PROP
VALVE, BRAKE BOOSTER, ETC) $1100
OEM WING $100
POWER MIRRORS PAINTED WHITE $75
FRONT BUMPER CUT 4 I.COOLER $100
STEERING WHEEL W/AIR BAG $100
DASH BOARD $75
SHIFT LINKAGE $50
INTAKE MANIFOLD $75
THROTTLE BODY $60
FLYWHEEL $50
REAR LOWER ANIT-SWAY BAR $50
OEM REAR LOWER CONTROL ARMS $50
99 CIVIC SI OEM PARTS:
COMPLETE SUSPENSION SOLD
LOWER CONTROL ARMS SOLD
FRONT UPPER ARMS SOLD
OEM WING $100
OEM POWER MIRRORS $75
THROTTLE BODY $100
INTAKE MANIFOLD $150
CAM & CAM GEARS $100
S4C B16AS HYDRO TRANY $600
TAIL LIGHTS $75
DRIVER SIDE FENDER W/ JDM
SIGNAL CUT OUT SOLD
EXHAUST W/CAT $150
RADIATOR AND FAN $75
FLYWHEEL $50
FUEL RAIL $40
INJECTORS $60
VALVE COVER $50
RADIO HEADUNIT CD PLAYER $100
POWER STEERING UNIT $80
A/C COMPLETE $300
STOCK PT2 ECU $100
OEM EBP FRONT LIP SOLD
OEM SHIFTER $40
OTHER MISC PARTS..JUST ASK!!!
AFTERMARKET PARTS:
SKUNK 2 68MM THROTTLE BODY $150
HONDATA S200B W/BOOST & DATA
LOGGING. $275
GSR HYPER PRESSURE PLATE $100
EXCEDY STAGE 1 PRESS. PLATE $75
TURBONETCIS T3 60-1 TURBO $550
3” DOWNPIPE W/ FLEX PIPE $125
OBX EXHAUST MANIFOLD $125
REVHARD INTAKE MANIFOLD $225
RC 1000cc INJECTORS $250
T.NETICS EVOLUTION WASTEGATE $150
GOLDEN EAGLE VACUUM BLOCK $25
BLOX FMU (GOLD) $40
MANUAL BOOST CONTROLLER $25
RS TYPE BLOW OFF VALVE $40
3 BAR MAP $75
PILLAR W/BOOST GAUGE & H20
TEMP (BOTH ARE AUTOMETER) $100
MISC. INTERCOOLER PIPE $25
JDM GSR HEAD- FULLY BUILT FOR
TURBO BY MIKE LASKEY @ LAKSKEY
RACING. HEAD WORK INCLUDES: STAGE
3 PORT & POLISH, 3 ANGLE VALVE JOB,
MILLED, HOT TANKED, SURFACED, CRACK/
LEAK TESTED, ALL NEW SEALS, SUPER TEC
INNER & OUTTER SPRINGS, SUPER TEC TIT
ANUIM RETAINERS, SUPER TEC TITANIUM
VALVES W/ BLACK NITRIDE OVERSIZED .5
FOR BOOST.
$1800
FOR SALE
OEM WING $100
DASH BOARD $75
SHIFT LINKAGE $50
INTAKE MANIFOLD $75
THROTTLE BODY $60
FLYWHEEL $50
OEM WING $100
THROTTLE BODY $100
TAIL LIGHTS $75
SIGNAL CUT OUT SOLD
EXHAUST W/CAT $150
FLYWHEEL $50
FUEL RAIL $40
INJECTORS $60
VALVE COVER $50
A/C COMPLETE $300
STOCK PT2 ECU $100
OEM SHIFTER $40
AFTERMARKET PARTS:
LOGGING. $275
BLOX FMU (GOLD) $40
3 BAR MAP $75
FOR BOOST.
$1800
Bump!!! Ttt.... Nobody needs parts ??? If u need something and dont see it on the list...ask me...i just might have it...
for those of you too lazy to click on the attachment and open it...here you go...
FOR SALE
JDM GSR HEADER W/HEAT SHIELD $150
VALVE, BRAKE BOOSTER, ETC) $1300
OEM WING $100
POWER MIRRORS $75
DASH BOARD $75
SHIFT LINKAGE $50
INTAKE MANIFOLD $75
THROTTLE BODY $60
FLYWHEEL $50
COMPLETE SUSPENSION $100
FRONT UPPER ARMS $50
OEM WING $100
THROTTLE BODY $100
HOOD $75
S4C TRANY $600
TAIL LIGHTS $75
HEAD LIGHTS $50
SIGNAL CUT OUT $25
EXHAUST W/CAT $150
FLYWHEEL $50
FUEL RAIL $40
INJECTORS $60
VALVE COVER $50
FRONT BUMPER (KNICKED) $40
A/C COMPLETE $300
STOCK PT2 ECU $100
AFTERMARKET PARTS:
OBX EXHAUST MANIFOLD $150
BLOX FMU (GOLD) $40
MANUAL BOOST CONTROLLER $40
3 BAR MAP $75
FOR BOOST.
$2000
FOR SALE
OEM WING $100
POWER MIRRORS $75
DASH BOARD $75
SHIFT LINKAGE $50
INTAKE MANIFOLD $75
THROTTLE BODY $60
FLYWHEEL $50
OEM WING $100
THROTTLE BODY $100
HOOD $75
S4C TRANY $600
TAIL LIGHTS $75
HEAD LIGHTS $50
SIGNAL CUT OUT $25
EXHAUST W/CAT $150
FLYWHEEL $50
FUEL RAIL $40
INJECTORS $60
VALVE COVER $50
A/C COMPLETE $300
STOCK PT2 ECU $100
AFTERMARKET PARTS:
BLOX FMU (GOLD) $40
3 BAR MAP $75
FOR BOOST.
$2000
its the front upper control arms i have for the si.. and the rear lower.. lemme know
suspension is still available...what do u need? just the si oem suspension? i also have oem gsr rear sway bar...oem lower control rear arms...oem front upper control arms...?? lemme know..
Everything is in excellent condition..the only thing i will need to check are the bushings on the upper front control arms...but i do believe they are in perfect conidition(no tears, rips, etc..)... as far as a deal..i will see what i can do...the prices are seriously pretty good already for all my parts..i tried to put them all a bit bellow what others are/have sold thiers for. what were u thinking as in "a deal"? and no im sorry no si rims. i will be able to tell you tomrrow about the bushings on the upper arms since i wont be home till tomorrow. sound good??
yeah. these parts will fit my 97 chivic ex right?
and i noticed your located in Cali . im in florida so we have to arrage the shipping too.
and yeah that sounds good let me know.
Thanx
Thanx
yes they will fit. the only thing i'm unsure of is the gsr rear sway bar..i will double check. but i am pretty sure it will fit. and yea we would have to arrange shipping. how would u prefer the parts be shipped? ups? fedex??? or? and yea i will let u know tomorrow for sure on the bushings. and i'll get pics tomorrow too. thnx!
ok cool. i can take the parts to a ups store and see what they would cost to ship and get teh pics and info for you...ttyl!
d.v.c
d.v.c
hey im interested in the jdm gsr trans w/ lsd and the jdm gsr header. i just need some speciifics on the trans more importantly, as far as mileage and whatnot. if u could PM me the details or email me the details along with the pictures, thatd be great.
eddiele76@me.com
eddiele76@me.com
it came off my jdm gsr swap that i bought from hmotorsonline. it came with around 30k miles on it..i put an additional 10-15k on it...so roughly 45k on the tranny...it has always had synchromesh in it to keep the gears nice and smooth. i do have pics of it that i can send tomorrow...i have not cleaned the tranny so it obviously is a little dirty..but none the less...it shifts like butter! no girds, pop outs..etc... and the headers came off the swap i bought from hmotorsonline also..they roughly have 30k on them..soon as i got the motor i replaced the headers..
