High Flow Fuel Filter..?
Old Dec 30, 2008 | 05:28 AM
ImPuLsIvE's Avatar
Default High Flow Fuel Filter..?
Is it worth it?
Looking at this model:
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
Keep it in mind it would be for my turbo application, and the fact that I don't believe my fuel filter has EVER been replaced
Should I go for it, or scrap the idea and just go with an OEM unit?
Old Dec 30, 2008 | 05:55 AM
Acidcrakker's Avatar
Default Re: High Flow Fuel Filter..?
I dont see why you would need it. your fuel system is pressurized. Never once have I heard of someone needing an upgraded fuel filter.
The most Ive ever seen in upgraded fuel systems, is fuel pumps, fuel rails, injectors, and AFPR's.
Old Dec 30, 2008 | 06:11 AM
ImPuLsIvE's Avatar
yep. and even then, the OEM fuel rail is more than adequate. The fuel pump, and injectors have already been upgraded, and I have no need for AFPR's due to my ECU tune..
I guess I'll just get an OEM filter just to say the filter's been replaced. It's currently got over 300K kms
Old Dec 30, 2008 | 03:28 PM
Kronn 98SH's Avatar
DON'T DO IT!
I bought that exact filter for mine, and boy was it a bad idea. The POS started leaking after less than 1000 miles. Plus, it uses a metal screen as the filter element, which doesn't block much of anything. The gas that was getting past the leak was filthy. Complete waste of money.
Fuster_Cluck
Aug 27, 2007 02:51 AM
prison_snitch
11
Jul 4, 2006 12:26 PM
NinjaTech
Jun 3, 2005 02:56 PM
laughinxxx
Mar 24, 2003 09:13 AM
