TYPE R,SPOON,JASMA headers em1??
i want to put headers in my em1 but i dont want to go wit the same o **** like every1 else wit bolt ons.basically the DC HEADER AND AEM INTAKE COMBO.so iam tryin to find out from past experinces with headers wat u guys wud recomend for a stock b16 in a 00 civic si dd??
jasma or jasport (spellcheck) but 1 of those
The toda b-series header is probably one of the best off the shelf headers you can get and its not very common. It is expensive however. Just a suggestion.
Good luck with your choice,
Sev.
Sev.
ya i know bout spoon but i heard u are jus payin for the name not really the performance.and how much wud the TODA headers run me??
The toda would run you anywhere from 800-1000 I think. I have seen a lot of dynos on
b16's and b18's. The toda makes the best numbers next to the custom headers like SMSP or Hytech.
Here's the best of the best i know of. I have one for my rsx. They custom make for all types of applications.
http://sixsigmaracing.com/bseries.htm
800-a g???
well i mean wud i be better goin wit that or like SPOON or MUGEN headers??
cause thats how much those run for right???
Just because some header has the name on it, doesn't make it the best.
Similar to your intake thread, there are many off the shelf headers that perform better than the stock exhaust manifold, but don't perform as well as a custom header that is tailored to your motors setup. Remember, the off the shelf headers are designed to perform on a variety of engine setups so one may perform well on one engine, while another header may not perform very well, and these headers could perform the opposite on another engine setup. When thinking about the off the shelf headers, the cheaper priced ones, for the most part, offer minimal performance gains compared to the stock exhaust manifold, where the more expensive shelf headers will usually perform better than the lesser priced headers which is obviously better than the stock manifold.
There are also custom headers that are tailored to your engines setup and will maximize its potential (provided that the engine is taking in the necessary air through the intake and dispelling it through a properly sized exhaust). These headers range in price from slightly more than the higher end off the shelf headers all the way up to a couple of thousand dollars depending on the options that you choose (1 piece, 2 piece - slip fit, mild steel - coated, stainless, etc.).
BlazinEK
Nov 3, 2004 06:18 PM
revhigh89
Feb 29, 2004 03:35 PM
PrjctDC2-R
Oct 11, 2001 05:26 AM
