is ti bad to punch ur turbo car daily
Old Aug 4, 2002 | 09:33 PM
turbogsr13z's Avatar
Default is ti bad to punch ur turbo car daily
every since i got my exhaust im peelin in every gear and the speed is great and my boost spiked to 10 cuz i got no cat now with 2.5 inch piping straight through which i set at 7 but its all good im sure my stock motor can handle it..anyways will i lose power if i gun it too much before i go to track??
Old Aug 4, 2002 | 09:59 PM
HybridKOOP's Avatar
Default Re: is ti bad to punch ur turbo car daily (turbogsr13z)
As long as you have the fuel for timing for it, 9-10 psi on a GS-R motor is fine.
Old Aug 5, 2002 | 05:54 AM
CovertFI's Avatar
Default Re: is ti bad to punch ur turbo car daily (HybridKOOP)
i do it to my stock d16 every day
Old Aug 5, 2002 | 11:43 AM
degradated's Avatar
New User
You will lose power if your motor blows. And from what I've seen, 10 psi on a stock GSR motor without fuel (assuming you are using an FMU setup?) is plenty to make you lose a ring or two, and probably much worse.
Old Aug 5, 2002 | 01:57 PM
SIK IN DA HED's Avatar
New User
Default Re: is ti bad to punch ur turbo car daily (degradated)
its always bad to abuse your car like that... but we all do! just keep within a safe boost level and make sure everything is all good...
Old Aug 14, 2002 | 01:37 AM
b18c5 turbo's Avatar
Default Re: is ti bad to punch ur turbo car daily (dlplayboy)
yep..i would most likely sey keep it at a good bo0st level and ull be fine..i mean there is a limit in which the motor cant handle it..but within a safe bo0st level..ull be fine..and only punch it when its needed..
Old Aug 14, 2002 | 08:05 AM
supergreenNA1's Avatar
New User
Default Re: is ti bad to punch ur turbo car daily (b18c5 turbo)
exactly. you're gonna feel like a real dumbass if you blow your motor just cuz "you felt like gettin on it." now.... if you blow your motor while smokin a corvette... i think that's 100% worth it... and makes for a great kill story.
frisbie21789
Feb 19, 2008 03:10 AM
94integragsr
Jul 27, 2005 08:06 AM
KillaB18
Jun 1, 2005 03:30 AM
jdmlove
Jan 1, 2005 12:42 PM
DualCamEK
Mar 13, 2003 07:35 AM
