Whats this mark on my crank Pulley
Old Dec 29, 2008 | 06:45 PM
butter99's Avatar
Default Whats this mark on my crank Pulley
95 H22A civic crank pulley
Do these two circles have anything to do with TDC ?
It would be nice to find the crank TDC without taking the pulley off.
I have to set my cams at TDC.
Old Dec 29, 2008 | 07:11 PM
RaysBoomBoomLude's Avatar
Default Re: Whats this mark on my crank Pulley
Its to balance out the weight......
Same way they balance out the crank weights.
Old Dec 29, 2008 | 07:14 PM
there should be an arrow on the inside timming belt cover.
and there should be a small slit on the TOP\MIDDLE of the crank pully.
Its hard to see, ususaly covered up with dirt.
also, it should be in the haynes.
Old Dec 29, 2008 | 07:23 PM
butter99's Avatar
oke dr pepper
So I might be able to see the mark on the pulley without taking it off?
Old Dec 29, 2008 | 08:36 PM
92civlude's Avatar
The timing marks are also on the flywheel. there is a rectangular shaped rubber plug on the transmission bellhousing just in front of the distributor. pull the plug out, there is a pointer cast on the engine block. Turn the crankshaft until you see the white T for TDC or the 3 red marks for the timing mark.
Old Dec 30, 2008 | 10:58 PM
butter99's Avatar
Thx for the info guys but I have a new problem
I must have tightened my valve cover nut on too tight.
Now the nut just spins with the stud!
How am I going to get it off so I can get my valve cover off?
fourthaxis
Jan 5, 2013 06:57 PM
DAintegraGSR
Aug 30, 2009 06:34 PM
Nextelbuddy
Mar 29, 2004 03:38 PM
Nextelbuddy
Mar 29, 2004 11:43 AM
