coolant leak
Old Dec 29, 2008 | 06:04 PM
Psych0Thrasher's Avatar
Default coolant leak
got a 96 honda accord with a coolant leak. i thought i was a head gasket but after thorough investigation i found that the leak is coming from a hard pipe that runs to some aluminum piece that has a bleeder valve and a coolant hose that runs from the bottom of the of the radiator. i think it's the intake. the aluminum "flange" is right next to what i think is the egr valve. my first question is what is this hard pipe called, and can i repair this leak without buying a new one. can i use rtv on it or something. it's not spraying but it's a pretty constant drip. any help would be appreciated. thank you
Old Dec 29, 2008 | 07:51 PM
alkoholikwun's Avatar
Default Re: coolant leak
if you could a pic would help, and then circle the spot
Old Dec 29, 2008 | 08:36 PM
YeuEmMaiMai's Avatar
check the hoses also, remove hard pipe, inspect for cracks and then reinstall with new gaskets. since oyu are draining the cooling system, replace all of your hoses as well.
Masho2013
Dec 4, 2013 11:36 AM
Mishako129
Apr 11, 2013 05:01 PM
Cyber ITR
Jul 19, 2006 09:58 PM
97akwerd
Jul 30, 2005 08:43 AM
