Idle Problems with my 91 Si
Hi everyone new to the forum was wondering if you guy's can help me out i have a 91 Si I swaped the engine in, cant get it to run right, it idles really ruff and it stinks bad like raw gas, i just recently did a tune up on it and it still runs bad.
any suggestions on what it could be?
If the wires,cap,and rotor are ok. I would check the ECT sensor. It may be biased rich. Unplug the ECT while its running. If you unplug it, the ECU will ignore the ECT input and go to a standard programmed parameter. and if a biased rich ECT is causing the problem, It will run better in standard parameter (limp mode). however, the ECU will store a code 6 or 7 and the check engine light will come on.
Alright man with your idle problems here was my deal.
I bought this prelude from a dude who did an h22 swap.
He told me the vacuum hoses werent hooked up right.
After 3 weeks of idle surging i checked one hose and it was leaking
put a new hose on it an wah lah
check all your hoses feel for air, make sure they are all on correctly and snug
hope this helps you
hope this helps you
