Need pic: side of ZC head.
I need a pic of the dizzy side of a ZC(DOHC) with the cam sensor and dizzy removed. I want to see if things "look" the same. If you don't know how to post a pic, email it to me.
Reason?.... https://honda-tech.com/zerothread?id=243109 still trying to get this on right!
Thanks
[Modified by 1990hondaHF, 1:06 AM 8/5/2002]
[Modified by 1990hondaHF, 1:07 AM 8/5/2002]
Thanks
going off memory here, but i am pretty sure the dizzy has to "teeth" that fit into two grooves on the intake cam and the cam angle sensor has two "teeth" as well.
hey peeps..i was wondering if he could use a si dizzy..it will fit in there just maybe the slots wont line up..but as long as one slot is lined up it would be fine..
and then just put a cam seal over the other hole. it would save wiring time for the si's..plus sometimes the zc's are know for blown dizzys
...and the si dizzy has a built in cam sensor....am i onto sumtin ingenious or will it just not work??
hondacrxturboSi
Apr 28, 2007 02:00 PM
-[sphEre]-
13
Oct 14, 2004 08:08 PM
