greddy t18 turbo kit
Old Dec 29, 2008 | 12:24 PM
YAGGA_YA's Avatar
Default greddy t18 turbo kit
how can i add boost on a stock greddy turbo kit.
Old Dec 29, 2008 | 03:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: greddy t18 turbo kit
aith a boost controller or shorten the wastegate rod if it is adjustable.
Old Jan 5, 2009 | 08:36 AM
YAGGA_YA's Avatar
i want to use a turboxs boost contloller so jus install it and then shorten the rod and it will be good.
Old Jan 5, 2009 | 09:18 AM
vy3tnamezz's Avatar
if you have boost controller just use that. no need to mess with that rod ****.
Old Jan 5, 2009 | 12:53 PM
TheShodan's Avatar
Moderator
Greddy T18 turbo? LoL..
Old Jan 5, 2009 | 01:21 PM
thewrai6th's Avatar
Unless you have a wideband, ignition harness and the eManage software, don't do it. You WILL run lean/advanced/detonate, lift your head or otherwise blow your engine. Any changes to your wastegate can put you into an untuned area of the injector maps.
Old Jan 5, 2009 | 01:45 PM
TheShodan's Avatar
Moderator
The boost controller idea is ok, if you plan to tune at the same time. Plus, you can't do that based upon the blue box coming from the kit itself, it will change the timing back to what is on the ECU, and there could be some problems.
Old Jan 11, 2009 | 06:24 AM
YAGGA_YA's Avatar
im using a hondata that was tuned by je imports.i have a 4 bar map and some 880cc injectors.im olnly running the greddy kit until i can get my money right.
Old Jan 12, 2009 | 12:32 PM
93CX's Avatar
Then get a boost controller and go back for more tuning.. Enjoy
Old Jan 12, 2009 | 02:56 PM
TheShodan's Avatar
Moderator
the wastegate will limit the amount of boost is allowed.
Old Jan 14, 2009 | 11:00 AM
YAGGA_YA's Avatar
thats what i was thinking too.cause its like a 7psi spring
Old Jan 14, 2009 | 12:16 PM
vy3tnamezz's Avatar
im running the 18g turbo with the internal wastegate at 9 psi on a gsr. works fine for me.
Old Jan 14, 2009 | 04:35 PM
YAGGA_YA's Avatar
how do u get it to 9psi
Old Jan 14, 2009 | 07:06 PM
TheShodan's Avatar
Moderator
The kit can do up to about 12psi, then the actuator must be changed. If you have hondata, use a boost controller, and have the car tuned to 9psi, which is about 240 whp or so
Old Jan 15, 2009 | 03:59 AM
YAGGA_YA's Avatar
im making 249 right now.
Old Jan 15, 2009 | 08:30 AM
TheShodan's Avatar
Moderator
If this is a b18 Integra kit, you can go to about sub 300whp, after that, you'll need to change some hardparts, like the downpipe itself, boost controller, and possibly the actuator.
The greddy kit for the integra was intended as a "bolt on" setup, with no real adjustment capabilities (at least not easy ones.) Nowadays there are people selling the better parts to upgrade their greddy kits, but you'll have to search around a bit.
Old Jan 15, 2009 | 02:33 PM
YAGGA_YA's Avatar
what can i do the down pipe.i cant find a actuator for that kit. help anyone
Old Jan 15, 2009 | 02:44 PM
TheShodan's Avatar
Moderator
the boost controller can be a manual. (The wastegate can adjusted from the boost controller). The downpipe can be made past the adapter elbow that came with the kit. There is someone that that does make a downpipe from the turbo back, but you may have to search for it.
Freshdot
May 15, 2010 07:55 PM
rjc898
May 16, 2005 09:03 AM
ktran1
Apr 20, 2004 10:01 PM
TurboLude00
Oct 25, 2002 10:10 AM
falcongsr
Aug 29, 2002 01:25 PM
