Odd brake feel on a 95 hatch.
I have a 95 cx and when I slow for a red light or a stop, my car slowly pulses as it comes to a stop. I feel nothing odd in the pedal or the steering wheel. I recently replaced the rotors (7K ago). A friend's Del Sol does the same thing. Anyone know what is wrong or at least having the same problem? Thanks.
I know I don't have ABS. And the pads and rotors are wearing normally. It doesn't seem to get any better or worse when they heat up.
did you guys screw in the rotor-retaining-screws completely?
if not, they may have your wheel a bit off.
or you may have to remove th rotors and clean the mating surface on th ehub to get them square to the hub.
otherwise, I dunno.
otherwise, I dunno.
mikehinkle
Mar 18, 2015 01:40 AM
